Results 1 to 8 of 8
    Default wakeboard rope ?
    what is the plastic sleeve that goes over the rope for?. I have a roped and it got all knotted up so the plastic sleeve is creased,cracked etc. can i just remove it.
    Aug 2009
    Montana
    i think it's to protect the board when getting pulled up?
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Des Moines, IA
    I like the coated because it keeps rope burn to a minimum. I know there are high quality uncoated lines too, but I'm not sure if they are the same as a coated line with the coating removed.
    Feb 2005
    Ottawa, Ontario, Canada
    It keeps the rope from forming a loop anywhere near the rider in case of slack during a crash. It won't get wrapped around a limb. I'd say that it's time to make that your backup rope and get a new primary rope.
    2005 XLV, upgraded ballast, Comptech swivel wakeboard and hydrofoil racks, Monster cargo bimini
    Dan, you must be doing some tricky stuff. I am justr doing w2w and switches. so hopefully removing the coating thats all friqued up wont hurt too bad.
    Des Moines, IA
    No, just rope burn from when the boat driver is dragging the handle to me.
    gotcha....
    Nov 2008
    ditto on the rope burn, and it's great for not getting knots in your rope... but it also make it much harder to cut.
    I got one wrapped around the prop, and it took forever to cut through it. Of course, that was with a pocket knife.
    '19 MAX
    '13 Mobius LSV - Sold
    '05 Mobius LSV - Sold
