Results 1 to 10 of 16
08-26-2004, 02:23 PM #1
Outback vs Outback LS vs Outback LSV
I am trying to decide between which of the 3 outbacks I want. I have one son that wakeboards and one son the slaloms. I like the seating layout of the LSV (seems to have more room). How is the slalom wake on the LSV. How is the GPH on any og these boats. I have never owned an inboard, only I/O drives. Please help me with my decision.
Thanks.Clark
2017 Moomba Craz
Raptor 400
Pacific Blue / Graphite
1st - 1983 old brown boat - not sure the make
2nd - 2001 Bayliner 185 4 cyl. Sold
3rd - 2005 Moomba Möbius LSV. Sold
08-27-2004, 09:39 AM #2Senior Member
- Mar 2003
- Dearborn, Michigan
- 193
Replying to Topic 'Outback vs Outback LS vs Outback LSV'
Clark,
Our family currently owns a 2003 Outback LS and we enjoy the boat very much. I would encourage you to really think about what you primarily intend to use the boat for, recreational skiing, open water slalom skiing, competitive slalom skiing, or wakeboarding. Once you have that figured out, think about where you might be in a year or two... more slalom or more wakeboarding. If all things remain fairly balanced I would suggest the Outback LS with the factory ballast and tower. If you are going to be more of a skiing family opt for the straight Outback. And of course if wakeboarding is where you see your family, look at the Outback LSV with all the appropriate options. We are already looking at different Supra and Moomba models because we didn't really think ahead. My family has really moved into wakeboarding and we didn't set up our current boat that way. So I have ended up adding the wakeboard accessories we need.
You asked about the wake on the LSV, it will be large if compared to tournament direct drive inboard boats. Too much weight in the rear of the boat. Works good for wakeboarding though.
I think most people are experiencing about 5 gph in the fuel consumption area while towing skiers or boarders.
Some other items to think about are; will you keep the boat in the water or will you trailer to the lake each time. If you intend to trailer I would suggest a double axle trailer. I would also opt for the fuel injected motor over the carb model (ours is carbureted). The hydraulic wakeplate should be a must, and I wish our boat had the upgraded carpet. Good luck, whatever model you end up with will be great. Moomba makes awesome boats.Jeff
Dearborn, MI
08-27-2004, 10:31 AM #3
Thanks for info.
There are several togh issues here. Like I said one will only wakeboard, the other does both. Neither are at high skill level, recreational all the way. They both want to improve. Why did you choose the LS over the standard Outback. The only difference I see is the ski locker and 4" longer. Is there more? We really need storage space. We normally carry 2 sets of skis in case others want to ski (double), or just like the wider skies. I realize the wakeboard tower and racks will take care of the wakeboards. I love the configuration in the LSV because of the room we are accustomed to in the old I/O we had. I am going from an 18' Bayliner runabout to whatever I buy next. It will be at least 20' with a V8. I am concerned the LSV wake will be too much for the slalom skiing, plus it is $4000 more than the Outback. I have never owned an inboard before, but am told it is the only way to go. Also, I have been told that inboards have a harsh ride, and from 2 different people that own a Moomba Outback, was told that 9 GPH was the norm. I realize the more info I get the better off I am, so please give me all the info you can think of. Another issue is my boys are 16 and 19 yrs old. I will paying for this boat for a long time. Even after they are grown and gone, I am sure they will continue going to the lake with us, but are either of these boats something I will enjoy while just cruising the lake with my wife?
Why the fuel injection instead of the carburator? With this option, don't you have to upgrade and get a larger engine? I am thinking more gas for more HP? Help me with this too.
Like I said,,, a lot to consider. I have heard lots of good things about Moomba, but still trying to decide whether to buy inboard or I/O with a V8 and tower. Problem is,,, when you buy a 20-21' bowrider with a V8 and tower, you will spend more than even the Moomba LSV.
Please, anyone, give me all the infoyou can to help me with my decision.
Thanks for taking the time with my investment choices.Clark
2017 Moomba Craz
Raptor 400
08-27-2004, 05:11 PM #4Guest
The Outback and Outback LS have different hulls. The Outback is a straight, tournament-approved slalom boat. The LS has a deeper hull, actually the same hull as the Mobius. Hope this helps. I would think the LS with a tower and some ballast options might be your best bet.
08-27-2004, 05:16 PM #5Member
- Jan 2003
- Nashville
- 57
The Outback is a different hull from the Outback LS and the LSV. The Outback is a straight, tournament-approved slalom hull. It is not intended for wakeboarding. The LS and LSV hull is deeper. The LS is more of a cross-over boat and the LSV would be more geared toward wakeboarding. Sounds like your best bet might be an Outback LS with a tower and a ballast set up.
08-28-2004, 01:36 AM #6Senior Member
- Aug 2002
- Bismarck, NorthDakota
- 579
I would highly recommend test driving one of each and see what the wake is like on an LSV with the wakeplate. I am told it is not bad at all. I have a 2001 Mobius d-drive, My thought was I still ski and haad the same concerns you do about the wake. Turns out I very rarely ski anymore, all boarding. So I sit with a 2001 d-drive and I now want a v-drive. I also think the v-drive would make a better "crusier" for you and the wife when you are out alone. (more room to play)
Bruce Fuerstenberg
08-28-2004, 04:04 PM #7Senior Member
- Jan 2004
- Austin, TX
- 145
Clark,
As others have said, the Outback hull is a ski hull whereas the Outback LS and LSV have a hull designed for wakeboarding. So you know, the Outback LS is equal to the Mobius LS and the Outback LSV is equal to the Mobius LSV. The difference between these pairs is that the Mobius comes outfitted for basic wakeboarding as standard equipment (for example a tower, a single bag Bertha Ballast system, etc.). There are Mobius upgrade options such as a hydraulic wake plate, a 3 bag Bertha Ballast system, and some others. However, you can add options to an Outback LS and LSV which would then make it exactly the same as its Mobius brother. I believe it is intended that adding options to an Outback model would cost slightly more than the equivalently configured Mobius (although I am not certain of this). Like others, the Outback/Mobius LS is more of a cross-over boat than the LSV.
As far as gph, I have a 2004 Mobius LSV 310hp carbureted engine with the single Bertha Ballast in the ski locker. I add two 540lb fat sacs in the compartments alongside the v-drive engine. We usually have 3-5 people in the boat. I typically get right around 5 gph. I have never seen it at 9 gph.
I likewise would go with the 320hp EFI engine instead of the carbureted engine. The only difference between the 320hp EFI and the 310hp carbureted engine is the EFI - same engine, just EFI instead of carburetor. You can also upgrade further to the 340hp MPI engine, but I think that's overkill. I have had no problems with my carbureted engine, but I believe the EFI is smoother and easier starting.Shoe
08-31-2004, 01:30 PM #8Senior Member
- Mar 2003
- 193
Clark,
You asked why we chose the LS over the straight Outback. For us we were looking for as much storage space as possible and we wanted a boat that rode a little deeper in the water (looking for that true cross-over wake). It does a pretty good job at both major disciplines, not perfect, but not bad either. The boat has a little bit more freeboard than the straight outback as well. That always helps in trying to keep water from coming over the bow when you turn around to pick up fallen skiers and boarders when it's choppy. We really do love our boat and use it all the time. The boat really has a lot of storage space.
You also asked about the ride for just cruising. My question to you is, how big of a lake are you on and does it get real choppy? Like maybe 1+ foot waves? Is it really exposed to wind. Our boat does ok, but when it gets real windy and/or there are a lot of boats out chopping up every bit of the lake, we usually head for the dock. These boats do not ride as well as true deep V hull boats. The LS or the LSV should be better than the straight Outback. The LSV and the LS have the exact same hull, no difference except for the placement of the engine.
A couple of things to consider when you decide on the engine, you will have an easier time starting the EFI motor in a cold or hot start condition. The EFI motor allows you to idle back away from the dock when the engine is still below the normal operating temp, nice when using busy public launches. Slightly better fuel consumption over the carb model. Slight increase in performance. And last but certainly not least, you will see a better resale value with the EFI motor. Like I stated before we have the standard 310 hp motor in out boat and it works fine, I also know that our next boat will be equipped with a EFI motor. Good luck.Jeff
Dearborn, MI
08-31-2004, 09:03 PM #9Guest
Thanks for the addtional info. I can't wait to drive one.
09-03-2004, 10:49 AM #10Guest
Thanks for info Jeff. The lake we are on does have super big waves except for certain weekends. One other thing I am contemplating is do I want the Mobius LS or the Outback LS. I really would like the space under the back seat, but on the other hand would like to flip a switch and load up the ballast tank. The EFI engine sounds good, but is around $1300 more. Thanks again for the info.. At least now I think I have narrowed it down to 2 boats...... I think.
Clark
WTB outback or outback LSV in TN or close to TN
By mpwonka in forum Moomba ClassifiedsReplies: 4Last Post: 02-09-2008, 08:06 PM -
06 outback
By csumerall in forum Pride & JoyReplies: 5Last Post: 06-01-2007, 03:48 PM -
2000 Outback vs Outback LS?
By daneav8 in forum General ChatReplies: 5Last Post: 05-29-2007, 05:07 PM -
New Outback
By MOOMBA_97 in forum General ChatReplies: 5Last Post: 03-05-2007, 10:50 AM -
Need HELP- 02 Outback LS vs. 04 Outback purchase
By husky fan in forum General ChatReplies: 8Last Post: 02-01-2005, 03:01 PM
