Results 1 to 3 of 3
Thread: light is out of ballast switch
07-27-2010, 11:42 PM #1Senior Member
- Oct 2009
- 102
is there a bulb in there that can go bad? My other two light up. When I run it either way I can hear the pump working, it just doesnt light up red.
07-27-2010, 11:51 PM #2
I had the same problem. With mine the common wire came disconnected on the back of the switch. Just unmount the switch and rehook the wire.
Nate
08-03-2010, 04:43 PM #3
Had the same issue. Jumped under the dash and found a spade connection loose. Put that back on snug and the light came back on. I'd be surprised if the light buld itself was burnt out. But I am sure there's an easy replacement buld for those - if not an entirely new switch.
2015 Supra SC400
08 LSV - Sold
Go big, or go home.
