Results 1 to 7 of 7
07-27-2010, 10:26 AM #1Senior Member
- Nov 2007
- 190
Shaft leaking after marina repack?
Hi all, I had the marina repack my shaft (that sounds nasty) last month. I've only been out twice since. Last time it was leaking enough that the bilge kicked on every 10 minutes or so. Is it possibly just something loose that I could tighten? It's a 5hr round trip to the shop, so I'd rather avoid it if possible...
thanks05 XLV
6 Polk Momo 6.5s/Kicker 850.4 for 4 rears,Kenwood stock amp for front 2 speakers, NVS Deviant tower speakers/Kicker 850.4, Kicker 12L7/Kicker 1000.1, Soundstream powerplant distribution (awesome unit), Wetsounds WS-420/Sirius Stiletto 2 in dock, Kenwood, KDC-MP435U/KnuKonceptz wiring, Pair of Optima Bluetops with stinger relay
07-27-2010, 10:35 AM #2
As long as you tight the nut by hand you can't break anything
____________
03 Mobius LSV
07-27-2010, 10:50 AM #3Senior Member
- Jun 2010
- Lake Houston
- 656
Search "shaft packing"
Go to the first sticky you get to...2013 LSV
2005 LSV - SOLD
07-28-2010, 12:53 AM #4
You will need to adjust it again. When you repack it and use the boat for the first few hours it will "break in" the new packing and start dripping again. You will have to tighten the nut up.
I always end up adjusting mine every few weeks and just tighten the locking nut by hand so I can just adjust it on the water without having to use any wrenches....'99 Outback (Maroon/Creme) GM 350/Holley 4150
550 HRS
LaSalle-Peru, IL
07-29-2010, 12:26 AM #5Junior Member
- May 2010
- San Antonio, TX
- 25
I just had to tighten my packing nut last weekend (thanks to Cab and others for their posts). It was leaking a steady stream of water when I went to launch the boat. I am not sure when the packing was last replaced (if at all). That will be an off season project of mine. I guess I will see what happens next year when I do. Hope it all works out for you.
2006 Moomba XLV Gravity Games
07-29-2010, 02:12 AM #6
Everyone says to hand tighten - but I have never been able to apply enough pressure by hand to significantly slow a leak when it occurs. Even using both hands (not so easy in the space available)
07-29-2010, 10:53 AM #7Senior Member
- Jan 2010
- Milwaukee, Wi
- 263
aaronwhitt82 laid it out perfectly....
08 Outback
82 American Skier
