Results 1 to 7 of 7
    Oct 2004
    Marietta, GA
    Default Tsunami 800 elbow adapter
    Does anyone know if the 90 degree adapter on the Rule 700 ballast dump pump will work on a tsunami 800 or do I need to buy the one sold on wakemakers?
    Aqua
    2005 Moomba 23 XLV
    340 HP, Clarion 5 HU, 2 Clarion wired digital remotes, 2 Wetsounds 485's, 6 Wetsounds XS 650's, 1 JL 12w6 Sub, 1 Wetsound WS420, 2 JL 300/2amps, 1 Wetsounds Sync 4 amp, 1 JL 500/1 amp. Teak swim platform, Perfect pass. Flip up Bow Light, Chrome tower Nav Light, Chrome thru hulls, Black Bimini, 2 750 Flyhigh bags, 1100 center Flyhigh bag, Acme 1235 14.25 x 14.5 prop, Dual battery system. Evolution Cover. Chrome Blower Vent Covers.
    Nov 2003
    Land O Lakes, Florida
    should be the same
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Dec 2006
    Tigard, Oregon
    Quote Originally Posted by Aquaholic View Post
    Aqua
    Aqua,
    If you buy the 800's from WM, they come with them. Otherwise, I didn't use the two that came with mine so if you want them, e-mail me your address and I'll send them to you for the cost of shipping.
    Al
    Al
    Oct 2004
    Marietta, GA
    Cab, How did you attach the hose to the shorter threaded side? Was it a hose barb or did you attach it straight on with a clamp?
    Aqua
    2005 Moomba 23 XLV
    Dec 2006
    Tigard, Oregon
    Aqua
    3/4 female thread x 3/4 hose barb bought from home depot. I wanted to minimize elbows to maximize flow rate so I went with a straight adapter instead of the supplied elbow.
    Al
    Oct 2004
    Marietta, GA
    Default Cab
    Did you see the Tsunami 1200 had two styles? One was a NPT and the other is not, I wonder if other saw this and if there is 1 1/8 to 1 inch or down to 3/4 adpater.
    Did you reuse the SC pump metal bracket with the 800?
    Aqua
    2005 Moomba 23 XLV
    Dec 2006
    Tigard, Oregon
    Aqua
    I don't have any T1200's so can't comment.
    I installed the T800's as fill pumps and did not use any brackets. I did not use them as replacements for the drain pumps as you are doing so can't help you with the bracket. Sorry.
    Al
    Al
