Results 1 to 10 of 28
07-24-2010, 08:04 PM #1Junior Member
- Jul 2010
- 2
HELP! Black swim deck prints on white seats!
Anyone else have black footprints on boat seats in their Moomba from the black "rubber" swim platform? Very hard to remove too!!
07-25-2010, 08:45 AM #2
me... when it start doing that, you better change the whole pad.
____________
03 Mobius LSV
07-25-2010, 10:29 PM #3Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
Untill i get around to replacing with Seadec as many on hear have done,i've clearcoated mine with spray laquer and problem solved at least temporary anyway. It does make it slippery but footprints stop as well.
Seadec is the better solution but this does work.07 Outback DD
07-26-2010, 11:36 AM #4
FYI, your Seadek pad order can take 4-6 weeks. Your CC will not be charged till the order is ready. If you want it, order it right away. Good luck!
07-26-2010, 01:30 PM #5Senior Member
- Jun 2006
- 194
I changed mine to seadek.....no more foot print problems now. And it looks way better. I did a 2 tone with Moomba on it.
07-26-2010, 04:02 PM #6Junior Member
- Jul 2010
- 2
What is seadeck?
What is seadeck and why do I have to fix/replace after just 2 summers?
07-27-2010, 06:35 AM #7
www.seadek.com - they make custom swim pads, it is much nicer then stock.
I am curious if people are having issue with a boat stored indoors OR if it is a weathering effect from the platform being outdoors all the time.
07-27-2010, 07:25 AM #8Member
- Jul 2009
- 55
07-27-2010, 03:41 PM #9
The issue is with the supplier of the black pads. The rubber oxidizes, as most things do in the sun, and degrades to a point where the pigment leeches out of the black pad. Thus, sticking to feet and whatever else and tracking all over everything.
The SeaDek is for sure the way to go. Turst me, I'm with you in the frustration in having to replace a fairly new pad - but you'll be happy you did. Even if my black pad hadn't been wearing out, I think I would have changed out the pad.2015 Supra SC400
08 LSV - Sold
Go big, or go home.
07-27-2010, 04:43 PM #10
