Results 1 to 7 of 7
Thread: Carb issues
07-22-2010, 11:17 PM #1Junior Member
- Jul 2010
- 2
Carb issues
I have a 97 Moomba Boomerang that is having carb issues. Shop has indicated that they are having a hard time locating a replacement carb (They also can not locate a rebuild kit). The numbers on my old carb are 80456-1. If this part is discontinued is there a replacement without any modifications? Any suggestions greatly appreciated.
07-22-2010, 11:37 PM #2'99 Outback (Maroon/Creme) GM 350/Holley 4150
550 HRS
LaSalle-Peru, IL
07-23-2010, 07:12 AM #3
I replaced my Holley 4150 on my '01 Outback (PN 75021-1) with one from summitracing.com. They are helpful if you call them. I have the old rebuilt one still in my garage (which may or may not be good). If you are close to Tuscaloosa let me know if you are interested in it.
2001 Moomba Outback, Indmar Assault 325 + 4BBL Holley
07-23-2010, 07:19 AM #4Junior Member
- Jul 2010
- 2
The boat has a 351 PCM engine. The shop has indicated that they have a call into the mfg to see what will interchange but I thought maybe someone on here may have already experienced the same problem.
07-23-2010, 10:15 AM #5Senior Member
- Jan 2010
- Milwaukee, Wi
- 263
yeah, a holley 4160 ought to do it.
08 Outback
82 American Skier
07-24-2010, 12:44 PM #6Senior Member
- Jun 2009
- Chester, SC
- 169
You can call holley directly and they can get you the number for the rebuild kit or carburetor. This is the route I went, but never actually got around to rebuilding mine. Symptoms have since resided after a few cans of SeaFoam have been run through it.
07-25-2010, 09:04 PM #7
Not sure why shops have problems finding rebuild kits for these. I am sure SKIDIM has this and I found this place on line that says they 10 in stock for your carb. Check out the link.
Holley's are the easiest rebuild out there.
http://www.marinepartssource.com/pro...Holley&mcat1=2
