Results 1 to 6 of 6
Thread: deck plate in trunk
07-20-2010, 10:46 PM #1
deck plate in trunk
quick access for visual check of actual fuel level in tank and to lube rudder assembly without removing panels
07-21-2010, 11:20 AM #2Junior Member
- Jun 2010
- Mexico
- 12
What size did you install?
07-21-2010, 08:02 PM #3
Size of Plate
I used a Beckson deck plate model DP40-B and with a flexible 18" extension on the grease gun, you can lube the rudder assembly without removing the floor panels. You'll see that I offset it slightly. Just remove the two screws on the left side to free it up for panel removal. It lines up exactly with the baffle/access hole through the fuel tank.
07-21-2010, 08:05 PM #4
08-11-2010, 12:14 AM #5Junior Member
- Jun 2010
- Mexico
- 12
more pictures please, very helpfull.
08-11-2010, 10:39 AM #6
Now I like that! I'll have to add that to my list of upgrades.....Thanks
Brings up a quick question - how often should you lube the rudder assembly?
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
