Results 1 to 10 of 15
    Sep 2009
    Muskoka, ON
    Default Rear Seat Back - Outback DD
    I have an 07 Outback and it seems that the port side seat back has "collapsed" a little from having the rear seat in the sundeck position. It is right at the top of the seat back where the seat would sit on when it is in the sundeck poisition.
    It is hard to see from the picture attached, but you can see that there is a bulge towards the centre of the boat and if you feel with your heard on the top of the seatback, you can tell that something inside has broken.
    Has anyone had this problem with the Outback DD?
    2007 Outback DD
    Jan 2010
    Milwaukee, Wi
    That sucks. Haven't experienced that on my 08 DD.
    08 Outback
    82 American Skier
    Calgary Alta Canada
    Cool
    Me neither and i have an 07 as well but we seldom have the seat up in sundeck location other than when we surf. I'm curious to know what to look for and what the solution may be.
    Some creative mind i'm sure will speak up.
    07 Outback DD
    Jun 2009
    St.Albert, Alberta, Canada
    Default same problem
    I have an 06 Outback with the exact same problem on the starboard side. it started about 1 year ago and has gotten worse to the point that it is now ripping the upholstery. I would also like to know if anyone has fixed this problem and how? The seat is not a snug fit between the gunwales in the sun lounge position and if you get a couple of guys sitting on it it seems to bend the support bracket. Any possibility of a recall or TSB from Moomba?
    Sep 2009
    Muskoka, ON
    I would think that Skiers Choice would cover something like this under warranty. I have used the seat in the sundeck position a total of 2 times I think! My boat barely has 70hrs. on it.
    2007 Outback DD
    Jun 2009
    I would agree that it should be covered as I think mine was only used for one summer and probably only had 60 hours on it when I noticed it.[now has 95 hours]. I looked in behind it and found 2 bolts coming through but unfortunately when I tried undoing the nut the bolt turns as well. I will have to talk to the dealer and see if they have repaired any of these and see if I can do it myself.
    Jun 2009
    Talked to the dealer today and they spoke direct to SC. SC say it is an abuse issue and not a design flaw and suggest someone must have jumped on it. the bracket is $60.00 and I will try to install it myself. Has anyone els had this issue???
    May 2007
    Richmond, VA
    No issue here. Have an '07 Outback w/ 150+ hours. Use seat in down and sunpad position. I ask people not to step on the seat getting in and out of the boat.
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    Jun 2009
    I removed the seat back and pulled apart the upholstery to see what part was needed. the part that bent was only held in place by 6 staples. I will remove the staples and replace with SS screws. Knowing that 200 lb plus people may be using this as a sun lounge that they would have made this a little beefier. Anybody want to see pictures of the repair? Klipper- Have you had yours repaired yet?
    Doug
    May 2007
    Richmond, VA
    Quote Originally Posted by dkremp View Post
    Anybody want to see pictures of the repair? Doug
    Doug - I would appreciate seeing pictures. Thanks. - Deerfield
    2012 RAM Crew Cab
    Stuart
