Results 1 to 6 of 6
    May 2010
    Appleton
    Default Winterize Ballast system?
    This will be my first winter A. with and inboard and B. with a ballast sytem to winterize. Any helpful tips?
    Go big or go home!
    Des Moines, IA
    I'd love to help you in another month or so. Sorry dude, just way to early for my mind to start thinking about winterization!
    May 2007
    Richmond, VA
    bslide - What boat and ballast setup do you have? - Deerfield
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    What hemisphere are you in?
    Jul 2002
    London Ontario Canada
    Enjoy your boat man. But everything ya need to know is in the How to Information
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Mar 2004
    Wylie, Tx.
    I take the bags out, and wash them. Roll them up to get all the air out. I disconnect all the couplings at the fill valves and let them drain. I don't hook them up till the next season in case there is any water left in them. You can use an air hose to push water out of the fill lines and drain lines, only takes a few minutes.
    After I winterize the motor, I put a small ceramic heater in close to the motor and plug it in on days with the temp getting around 35 and below. No problems at all.
    Medic151
    06 Mobius XLV
