Results 1 to 10 of 14
Thread: Uhhh yeah...
07-13-2010, 10:11 PM #1Senior Member
- Jun 2010
- Lake Houston
- 656
Uhhh yeah...
07-13-2010, 10:14 PM #2
07-13-2010, 10:21 PM #3Senior Member
- Jun 2010
- Lake Houston
- 656
HA! I bought the boat on a saturday, took it out that evening at it was fine. 75 hours on the boat. Took it out on sunday and it was HOTTTTTT.....
07-13-2010, 10:36 PM #4
07-13-2010, 11:17 PM #5Senior Member
- Jun 2010
- Lake Houston
- 656
Yeah tell the guy I bought it from that!
07-15-2010, 02:17 PM #6
how oldis the boat.you can bet the motor oil ,filter,tranny and v drive may not have been serviced either then
09 21v LAUNCH
99 Outback LS. Sold
Doug
07-15-2010, 03:17 PM #7
lewisb13 - Which model boat do you have and where did you find the pieces that broke from the impeller? - Deerfield
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
07-15-2010, 03:21 PM #8Senior Member
- Jun 2010
- Lake Houston
- 656
All the fluids got changed at the beginning of this season so Im not too worried there. And since the engine was overheating it was putting the boat into "limp" mode to protect the engine which I thought was a cool feature so Im not too worried about having to change the oil since its still honey color. The boat is an 05 LSV. The pieces that I did find were caught in the tube between the trans cooler and the actual impeller. I didnt pull the other end of the tube off and feel around in there with my finger up at the trans cooler, but I will today.
07-15-2010, 09:44 PM #9Senior Member
- Jun 2008
- Eugene OR
- 1,786
umm for some reason the one on the left look a little wrong. I cannot put my finger on why but it might be a little lop sided.
I hope you found all the parts. You might want to pull the hose that goes from the impeller to the engine and make sure you do not have any hiding out.2008 Outback V - Sold but never forgotten.
07-16-2010, 12:39 AM #10Senior Member
- Jun 2009
- Chester, SC
- 169
I changed mine, original was in. Did not say "Johnson" on it as yours in this picture does. Looks like its been changed before in this case. Did you look at the inside of the impeller housing so make sure everything in there is smooth?
Only time I have really seen one in this shape is when the pickup was clogged with dirt and the engine overheated as no water was making it to the impeller....
