Results 1 to 10 of 11
Thread: battery
    Apr 2002
    fredonia/dunkirk ny
    Default battery
    I can't understand why my new 2002 moomba mobius battery goes dead after it sits for a day. radio off, key off. what could possibily be running to run battery down?
    Apr 2002
    I know this sounds silly but are you sure the radio is completely off. If it says "All Off" it is not off and you have to hold the src button down until the display goes blank. That is the most common cause for dead batteries. If that is not it let me know. Sorry for the inconvenience.
    Matt Brown
    Product Development Manager
    May 2002
    Canyon Lake, California
    Mine is hooked up to one of the accessory switches, It is good and bad, It definitely turns off, but it will not hold any memory preset stations. Is that how they are normally hooked up? That is how mine was installed anyway.
    Are you sure all the other switches are turned off? Do you have an Amp that is maybe staying on? Good luck I hope you solve this problem.
    Richard
    2001 Mobius
    May 2002
    SC
    We have been burned the same way twice. Sorry guys, but it is not a good design. We are going to add a switch to the radio to ensure there is no power to it in the future when switched off.
    Nov 2002
    Denver, Colorado
    Default Preset Memory
    CWS_Kahuna
    Actually, going through an accessory switch is not a bad idea. You said that you keep losing your presets and probably your clock I would assume. You can remedy this. On vehicles the stereo is wired through the ignition and when the ignition is not on there is no power to the stereo but how do they keep their presets and clock? All stereos have a separate power wire to power the presets and the clock. You need to isolate that wire and give it a dedicated power source. Your manual on the stereo can walk you through this. It is very convienent having a clock on board. Hope this helps!
    Kraig
    Default battery
    do a draw test in your diffrent circuit till you find what is making the draw and find the problem unit in that cicuit. use a multi meter on amp scale but do not turn any thing on with the meter hooked up or you will blow the fuse in the meter
    Jan 2003
    Minnesota and Wisconsin
    I have been told that electronic ignition or the computer that runs it or something is always drawing power. Not sure..
    How old is the battery?
    I am happy to get 2 seasons out of a battery, expecting only 1 season.
    http://bensonwdby.home.comcast.net/
    May 2007
    Naperville, IL
    Quote Originally Posted by BensonWdby View Post
    If the battery is six years old, it may just be shot. I would hope to get more that 2 seasons, but six is pushing it. Do you maintain the battery during the winter, either with a trickle charge or an occasional full charge?
    DFW, TX
    Quote Originally Posted by CWS_Kahuna View Post
    I'm not sure what radio you have but mine hold the presets when the acc switch is turned off.
    Sled491 Guest
    I would probably lean towards the old shot battery theory myself.
  1. Please help with second battery install
    By cj11302000 in forum General Chat
    Last Post: 06-25-2008, 02:23 PM
  2. Extra Battery
    By drewdwn in forum General Chat
    Last Post: 04-27-2008, 12:52 PM
  3. Second Battery
    By NC05LSV in forum General Chat
    Last Post: 07-06-2007, 09:41 AM
  4. battery
    By LSV04 in forum Service & Repair
    Last Post: 04-22-2007, 07:05 AM
  5. Battery dead
    By Wakesurfer in forum Sales & Information
    Last Post: 06-15-2006, 12:33 PM
