    Default Prop & Shaft to Hull Alignment
    I just bent a prop on my ’04 XLV on the mud/rocks but it was not a hard hit. I swapped the prop and the boat runs fine with no shutter, pull, or shaft seal leakage at all. The question is though when I looked from the stern up the hull the shaft is slightly aligned to the left. Is this normal, or should the prop and shaft be aligned exactly parallel with the hull? I know I should have noticed this before but I simply didn’t.
    Any pointers would be greatly appreciated.
    Thanks,
    -Kris
    May 2010
    Quebec City, Quebec, Canada
    Your strut is bent to the left?
    99% sure it's normal and your shaft is perfectly aligned...
    My 03 strut is factory bent to the left too..
    ____________
    03 Mobius LSV
    Default Bent to the left
    Correct it is bent to the left.
    -Kris
    Jul 2002
    London Ontario Canada
    the prop shaft and rudder do not line up so you can remove the shaft without removing the rudder
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
