07-03-2010, 01:17 PM #1Junior Member
- Nov 2009
- posey lake, mi
- 5
ballast tank filling when fill switch off
Does anyone know how to keep your ballast tank from filling when boat is moving and the fill switch is off? Mine continues to fill up everytime I take the boat out. The boat is a 2007 outback v. The pump isnt running but the bag fills everytime
07-04-2010, 10:20 AM #2
Look at the solenoid valves. There is a little black lever on them. They are the manual bypass switch. If they are in the "on" position, they are always open (will let water thru). Flip them to the off position and this should fix ur problem. Lets us know if u can't find the solenoids or the levers.
07-04-2010, 10:41 AM #3Junior Member
- Nov 2009
- posey lake, mi
- 5
I looked at the manual bypass valve is in the off position and water is still getting through. Maybe I just need to replace the whole thing.
07-12-2010, 12:08 PM #4Junior Member
- Jan 2009
- Southern Alberta
- 28
I have the same problem on my '06 outback V. I have changed the valve assembly and still have the water coming in (could the new one be faulty?). Using the Ball valve is a pain. any other suggestions?
07-12-2010, 12:26 PM #5Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
The little black lever on each solonoid should be perpendicular to the valve assembly if you do not want your bags to fill unless you have the helm switches on. At first I couldn't figure out which position was "on" and which was "off". I wouldn't think there was anything wrong with the valves, especially if all three are acting the same way with the solonoid switches in the same position on all three. If the switch(s) on the solonoid are in the parallel position to the valve then that bag will fill when any of the helm ballast switches are in the "fill" position. So if the little black switch on your port bag solonoid is in the parallel position, and you turn on the starboard helm switch to fill the starboard bag, then it will also fill your port bag.
Hopefully this makes sense.2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
07-12-2010, 01:23 PM #6
As the other said:
1- Check the little black level
2- Unsrew/clean the selenoid (in my case the little spring was misaligne).2008 Outback V black
07-15-2010, 03:30 PM #7Senior Member
- Apr 2010
- saskatchewan, canada
- 334
I just replaced all three to my sprinkler valves, super easy to do and now everything works great.
