Thread: Walkway ballast
    Default Walkway ballast
    Hey guys, I have one of those 370lb tube sacs that I'd like to put in the bow walkway. The sac looks like its quite a bit wider than the walkway. Any concerns about it pushing sideways on the sides of the walkway? Also, any concerns about the wt on the ski locker door? That wt will be mostly offset by the full sac in the locker but still seems kinda iffy...mostly the sideways pressure on the walls of the walkway. Anyway, everybodies thoughts'd be appreciated. Especially those that have been doing this for a while.
    Thanks in advance!
    Tyler
    BTW - its a 2003 Mobius DD
    Oct 2009
    Lockport, IL/Cloverdale, MI
    I've only done this once, this past weekend, and so no ill effects. My only concern was making sure the sac in the locker was filled first as it always pops the lid...didn't want the sac on top to restrict that.
    2008 Outback V
    Mar 2008
    Vancouver WA
    We used to do it all the time with a 650lb sac and never had any problems.
    PWI as usual...
    Sled491 Guest
    If you were concerened about the lateral pressure just don't fill it all the way. But 350 is not different than you and a buddy trying to walk by each other in the same spot.
    Cool, thanks! That was the answer I was looking for. Nobody ever wants to sit up there but it makes the wake so much better...problem solved
    2003 Mobius DD
