Results 1 to 2 of 2
Thread: Wake plate adjustments
06-28-2010, 05:22 PM #1
After getting my boay back from some cosmetic gel coat repairs, I noticed that the wakeplate does not go down as far as it used to resulting in a noticeable difference in ride. Is there a way to adjust the end points of the wakeplate? or do I need to take it in to a dealer?
BTW.. the wakeplate had to be removed and re-installed for thee repair work.2009 Moomba Mobius LSV Liquid Force. Indmar 340HP CAT
06-28-2010, 05:42 PM #2
I came across another discussion recommending the proper travel should be as follows;
Lowest position = 1" below bottom of hull
highest position = 3" above bottom of hull
Does this sound right?2009 Moomba Mobius LSV Liquid Force. Indmar 340HP CAT
