Results 1 to 3 of 3
Thread: Adding second battery
06-28-2010, 11:41 AM #1Junior Member
- May 2010
- 10
I have a 05 moomba I want to put in a second battery with a switch the problem I have is that they used 2/o gauge wire from battery to starter and know one makes a eyelet clamp that big to go to a small post. Has anyone encountered this problem.
06-28-2010, 01:11 PM #2
Yes, that is a common item that we offer. You just need a nickel-plated
2-ga terminal lug with a 5/16" I.D.
Earmark Marine
06-28-2010, 06:06 PM #3
What I did was get a set of these:
http://batteries.batterymart.com/bat...nal-post--list
I got them from a car parts store like Schucks or Auto Zone
They are threaded to screw onto those terminals on the back of the switch. I just drilled the rest of the way thru the terminal post, tapped it to match, and screwed it onto the back of the switch. This way I didn't need to modify the 2/0 cable and battery clamp that came stock. I had to cut the post down a little as it stuck out too far to mount the switch, but it being lead, it was really easy.
Not sure if that makes sense, but it's a super quick solution!2015 Supra SC400
08 LSV - Sold
Go big, or go home.
