Results 1 to 10 of 13
    Dec 2006
    Default Ideal Prop for Mobius LS
    I purchased my Mobius LS in 2007 with the upgraded 4 blade prop. When it was delivered it still had a 3 blade on it so I traded the 3 blade for a 4 blade with the dealership.
    Since then I have tried a variety of different 4 blade props and none seem to be quite right. In fact, my boat has never been able to go faster than about 34 mph which seems quite a bit slow.
    Does anyone know what the ideal prop I should have is?
    Our altitude here is about 3,300 feet.
    Thanks for any help.
    Dan
    Nov 2009
    Gatineau, Quebec
    Quote Originally Posted by Dannad View Post
    Dan
    My 05 Outback LS has a 4 blade OJ 13-13 at 4800 RPM i`ll hit 40 MPH depending on conditions what props have you tried
    2012 Mobius LSV
    05 Outback LS SOLD
    Jun 2006
    My 2004 Mobius LS came with an OJ 13 X13. I bought an ACME 543 as spare and I now use it exclusivley. You should be running some where around 40 MPH.
    Apr 2010
    Eastern Washington
    I have an 07 LS and it runs 43mph with the stock 3-blade at 1500ft elevation. Give ACME and OJ a call and they will know the right prop for your situation.
    p.s. I bought an ACME #913 earlier in the year but haven't had a chance to try it yet. It came on recommendation of the people at ACME for a wakeboard and surf specific application
    2007 Mobius LS
    Sep 2009
    Medicine hat Alberta
    I posted In the past that I had a 12x12prop. In actuality I have a 13x13 3 blade prop at about 4500rpm I do 40 mph which for me 6'3 250 is a bit slow for barefooting. I would love another 3 mph without mashing the throttle down. I would surely give up a holeshot for it.
    May 2008
    NW Montana
    Dan,
    We have 2008 LS with stock 3 blade prop, boat mostly at 3900 ft and top end is 42-43 at 4500rpm.
    2008 LS
    Aug 2008
    Long Island - north shore
    I own a '06 LS/325EFI with the stock 13/13 prop. I top out at 44-45 with a half load of fuel and 3 people on board @ 4,400 rpm.
    I am currently investigating prop options myself. We will be using the stock ballast, when wakeboarding as I am in the process of installing the ballast system myself (orig owner opted out of factory ballast set-up). The boat also does pulling duty for several slalom skiers as well, so I'm looking at the ACME 13x12 or 13x11.5 three blade CNC.
    Any suggestions would be appreciated.
    Sep 2009
    Möbius ls is much bigger than an outback so please clairify
    Dec 2006
    Thanks for your input guys.
    I'm going to get a few from the dealership to try out.
    Dan
    Jan 2007
    Stanwood, WA
    We have a 2007 Mobius LS, with the wake board prop I htink 11.75 X 12.5 I am good for about 37. I bought an OJ 13x13 four blade and I can et about 43 mph. The four blade is much quieter and smooth out of the hole as well.
