Results 11 to 16 of 16
Thread: Trailer bunk Shimming
06-18-2010, 09:08 PM #11
First question is what is the prop diameter? What is your current diameter?
I wouldn't shim more than 3/4" and if i was to i'd use synthetic material similar to HDPE or Trex deck material the same size as the bracket, i sure wouldn't use washers or such as that will only increase the pressure points and cause bowing of the bunk boards.2007 Mobius LSV
06-18-2010, 10:35 PM #12Member
- Jul 2009
- 55
Here you go...
Maybe this will help
'05 Supra 21V Launch
06-18-2010, 11:11 PM #13
And there's your answer in black & white 3/8" HDPE will work for the task.
06-21-2010, 09:41 AM #14
SSsmith: Please post where I can get that Supra Shim Kit?!?!
Put it this way, my dealer has never seen a trailer like mine with NO CLEARANCE, brand new from boatmate made for my Centurion. Yes my prop will touch the trailer by maybe 1mm unless I crank the bow stop as tight as I can. If I left it snug but not cranked, my prop can touch. I need a shim kit.
Will do this Fall when it's slow and leave the boat at the dock (opposite the ramp side) while I re-shim in the parking lot. Might re-carpet while there too.
THX. Great thread
07-22-2010, 10:03 PM #15
Sailing, did you ever get ahold of your shim kit? If so, did you order it from Boatmate or where? Thanks
07-23-2010, 12:05 AM #16Member
- Jul 2009
- 55
Sorry for the late reply.
I got the kit from Jerry at Boatmate. You can email him: [email protected]
Ask him for the shim kit and include your trailer serial number and your address in the email. He should take care of the rest.
Good luck.'05 Supra 21V Launch
