Results 1 to 10 of 10
06-15-2010, 10:57 PM #1Senior Member
- May 2010
- Muskoka, Ontario
- 427
Biggest amp size in LSV in stock location
Right now we have the stock 700.5 kicker and 250.2 kicker in the stock location under the front seat.
I want to replace the 250.2 with something bigger but not sure on what you guys have been able to fit in there with little to no modifications. I wish I could make a nice custom amp rack but don't have the time to be tinkering on the weekends when I rather be spending it on the water, so just looking for something that can fit in the space easily.
What have you guys fit in that spot? I am looking at anoter kicker (350.4) or larger, aiming for 200 watt RMS + per channel.
06-15-2010, 11:03 PM #2
loud,
Why don't you measure the area where you want to mount the amp to see how much room you have? Then go to sonicelectronix or kicker's website as they have the dimensions of all the amps posted.
AlAl
06-16-2010, 01:08 AM #3
I'm sure you could find a good class D amp but at a price. Class D would be small and more efficient.
06-16-2010, 07:43 AM #4Senior Member
- May 2010
- Muskoka, Ontario
- 427
06-16-2010, 10:02 AM #5
Class D can be a good solution where space is an issue. The Kicker IX amplifiers are full-range Class D amps that are running between 88 and 92 percent efficiency. You pay more for the technology, but you get what you pay for. Rigt now we have a 4-channel amp and some sub amps in our full-range Class D lineup. The IX500.4 will deliver 250 watts per side into a pair of 4-ohm loads, so you might look into that. Otherwise, I think you could still get a ZX450.2 or ZXM450.2 in there. Either of those stereo amps will deliver
150 watts per side into a pair of 4-ohm loads.
the IX500.4 has dimensions of 2.1875 x 7.875 x 9.375
the ZXM450.2 has dimensions of 2.125 x 9.625 x 16.75
Phil
Kicker
06-16-2010, 12:39 PM #6
the 450.2 amp is about the same size as the 700.5 and will produce the following.
4 ohms: 150 watts x 2 chan.
2 ohms: 225 watts x 2 chan.
Bridged, 4 ohms: 450 watts x 1 chan.
it really cranks.A Day at the Lake...Priceless
06-16-2010, 06:05 PM #7Senior Member
- May 2010
- Muskoka, Ontario
- 427
thanks
might have an issue with the 450.2 if its the same size as the 700.5
06-16-2010, 09:41 PM #8
sometimes you get what you pay for! I use 2 of the JL Audio MHD 600/4 class D amps. Really compact and full of clean power. Their even stackable if you are really short of room. Check them out.
2015 "NOT A MOOMBA"
06-16-2010, 10:02 PM #9
06-17-2010, 12:08 PM #10
Keep in mind this is in an Outback. I probably have 30% less room if not more in my cubby. 1200watts of class D clean power and takes up less space than most 5 channel amps
2015 "NOT A MOOMBA"
