Results 1 to 10 of 11
Thread: Center ballast locker question
06-15-2010, 10:33 PM #1
I think I've read it on here before but here goes. My bilge area is completely dry but my center locker always seems to have about an inch of water near the drain hole. So where does this water go? I've used my shop vac to drain the locker out but I notice if I lower my trailer jack all the way down, more water will flow into the locker from the drain hole...WTF? This is the only thing I hate about my boat.
06-15-2010, 10:52 PM #2
Do a search for "Nasty Mat" and you'll get all the answers you need.
06-16-2010, 01:45 AM #3
See the pic below. Problem is that the low point of the boat is under the fuel tank. So you can see in this pic that the bilge area is dry but there is about a half inch of water or so under the gas tank and that is what is finding it's way into your ski locker when you lower the trailer jack. One way to fix this is to put a second, compact bilge pump inside the 4" diameter hole in the gas tank and connect the line to the other bilge pump line.
Al
06-16-2010, 09:06 AM #4Senior Member
- Oct 2009
- 102
Also as I stated in the "nasty Mat" thread. I am actually getting water in the in the very front of the bow under the ski locker. Mine actually has water trapped under the ski locker. When I hit the bottom of the locker it sounds like Im hitting a waterbed w/ all the water under there. I am debating drilling a hole & sucking it out.
06-16-2010, 12:41 PM #5
Somebody on here the other day said he added an extra drain plug at the low spot on the boat. I guess you could do that.
06-16-2010, 03:46 PM #6
Some of the new boats (2010?) have a second drain plug access thru a small removal panel in the floor in the middle of the boat. I am guessing it lines up with the hole in the gas tank and that's where they put the plug.
If someone has a 2010 that has this feature, could you confirm this is what Skier's Choice did and could you post a couple of pics?
Thanks,
AlAl
06-16-2010, 03:57 PM #7
Al, that's a nice little square that comes out for the LSV, Anyone know if the OBV floor comes up that easy?
06-16-2010, 04:11 PM #8
I understand that they all do, it's just a matter of finding the "hidden" screws that hold it down. I have heard that they are hard buggers to find in the carpet..
06-16-2010, 06:06 PM #9
There was also someone who plugged the ski locker drain hole with a bilge type plug. I think it was Brain_Rinse. It looked like it works real good. I think you gotta buy a 1.5 inch plug, and grind it down to about 1.3-ish inches. That's what I think that hole measures out to be...
2015 Supra SC400
08 LSV - Sold
Go big, or go home.
06-16-2010, 08:30 PM #10
