Results 1 to 7 of 7
    Default Impeller debris in engine, 2001 Mobius
    I overtemped my motor today, because the impeller died. I couldn't get the RPM's much over idle, and when I finally realized it was overheating, the guage was pegged at 240. Removed the hoses, found debris. Removed housing cover, and impeller was shredded.
    Here are my concerns:
    1. I don't have a strainer in the water lines. How can I make sure I don't have rubber debris blocking the cooling of the engine? How can I get it out?
    2. What concerns should I have after overtemping the engine? Are there any checks I can do? Any inspections? Any worries?
    Thanks for your responses,
    Jimmy
    Feb 2006
    Birmingham
    Here is a thread with almost the same issue.
    https://forum.moomba.com/showthread.php?t=11544
    15 Mondo Surf Edition
    02 LSV - Traded In
    Quote Originally Posted by JesseC View Post
    I did see that, but not much info.
    I spoke with a mechanic today. He said the computer was cutting out my engine to protect it during the overheat. So, I feel that I probably did not hurt the engine internals.
    I've gotten a new impeller. I took the thermostat housing off, and found no debris. But, I'm having a hard time finding a new theremostat kit with the gaskets, locally. Hard to find parts for the Indmars. It's frustrating, because I'm guessing the kit is sitting on a shelf in the parts room, but I don't have a Mercury number for it.
    Mechanic said that if I don't find anything in the thermostat housing or the inlet to the engine water pump, there is really nothing I can do. The pieces will either settle to the bottom of the block, or be blown out the exhaust.
    J
    Jan 2010
    Milwaukee, Wi
    You need to check where the water pump hose runs into the transmission cooler.
    08 Outback
    82 American Skier
    Jul 2009
    Spokane, WA
    Exactly what Phosphor said. Pull the hose on the inlet end of the Transmission cooler. It's got a strainer on the end of that. If any place is going to collect impellar parts, it'll be here. I've found an impellar paddel there once. Just stick your finger in there and feel around. Probably will be a few pieces at least!
    Luckily, it sounds like your motor is still in good shape! Chock one up to the good guys!
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
    Good call on the transmission cooler. I had to go to Texas Mastercraft to get the thermostat kit, and that's exactly what the tech said. I guess parts can back flow to the trans cooler.
    He also explained that my engine was in "limp" mode, specifically to protect it. I'm confident that the overheat did no damage.
    Thanks for you help, guys.
    Summary, if you trash your impeller:
    1. Change it every year! Or, if you hear a wine from the engine compartment, check it!
    2. Check all your water hoses for debris.
    3. Remove the thermostat housing, replace the thermostat, and check for debris.
    4. Check the transmission cooler for debris.
    5. Carry a spare, in the boat.
    J
    When I pulled the hose off of the OUTLET side of the transmission cooler, the screen was full of rubber debris. When the impeller fails, most of the debris flows back to the transmission cooler as the water drains from the engine, out of the boat. If I'd not gotten this debris out of the cooler, it would have flowed right into the new impeller, and destroyed it.
    J
