Results 21 to 23 of 23
Thread: ****Depth Gage Problem****
06-24-2010, 02:12 AM #21Junior Member
- Jun 2006
- 20
mine is located by the close to the bilge pump right behind the gas tank
07-06-2010, 11:30 PM #22Member
- Apr 2007
- 38
My transducer came loose and slid around until it lodged under a hose, and it was tough to find as well. I had the same symptoms as many of you: it would work erratically and unpredictably. If I hit a wake just right it would work for a while and then stop.
07-10-2010, 03:20 PM #23
I searched for my transducer yesterday after reading this thread. I have the same symptoms as everyone else. Found mine directly in the center of the v-drive compartment underneath everything. The actual material that it was glued to had broken free, so it was just moving around down there I imagine.
I dried out the v-drive area and re-attached with 5-minute epoxy, so hopefully that will clear everything up... but like everyone else says, it was super hard to find.'19 MAX
'13 Mobius LSV - Sold
'05 Mobius LSV - Sold
