Results 1 to 10 of 11
Thread: New Prop?
06-14-2010, 10:53 AM #1Member
- Jun 2007
- 71
New Prop?
We tore up our prop this weekend and need to replace it. Which prop should I buy if the majority of the time we surf behind our 06 LSV?
06-14-2010, 10:56 AM #2
How much ballast and how many people most of the time? Do you do anything else? What? Do you need top end for any kind of distance (for example, I run 10 miles up river just about every time out)?
06-14-2010, 11:06 AM #3Member
- Jun 2007
- 71
We usulally run a 750 in the surf side but do wakeboard with them both full at times. We also have the center factory ballast which I think is 350. We usually go about 20 minutes from the dock on a normal day but not too worried about top speed. If I am just messing around and cruising we always empty the ballast. The only time our ballast are full is when we surf and board.
06-14-2010, 01:03 PM #4
If you don't run a super heavy load, I think Daze, Cab and I all agree that the 13.5 x 16 is the best all around.
Here was one of my comments from after the prop testing weekend:
4. If I could choose a prop I'd take the 13.5 x 16 for the same reasons Moombadaze and Cab like that prop. It will run 5000 RPM at the top end and push the boat just as fast as the 13.7 x 17 one (which only goes to about 4700 RPM). It gave improved holeshot over that one though. I don't run much ballast so the holeshot was absolutely fine for me and I'd like to keep the top end b/c I run 10 miles up river every time I go out. The prop also threw a nice clean surf wake.
Here was the thread from our testing efforts:
https://forum.moomba.com/showthread.php?t=10991My Mom said I'm not allowed to get wet!
06-14-2010, 01:10 PM #5
numbers from the box
Acme item #1161
13.5 x 16VL4B .135 cup
bore size 1.125Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
06-14-2010, 02:31 PM #6Member
- Jun 2007
- 71
Thanks guys!
06-14-2010, 05:58 PM #7Member
- Jun 2007
- 71
Jim at ACME convinced me to go with the Acme # 1847 - 14.00 X 14.25 VL4B 1.125"Bore .150Cup so that is what I did. If I'm not happy with it I can return it within 30 days. Again, thanks for the help.
06-14-2010, 06:30 PM #8
If you run with both 750's full and the 400 in the ski locker full for wakeboarding and you have 5 or 6 people on board, then I think you did the right thing going with the 14x14. I only run 1300#'s for wakeboarding so for that amount of ballast, the 13.5x16 is more than sufficient plus I didn't lose anything on the top end over the stock prop. I think you will be amazed at the holeshot you get with that prop.
Al
06-15-2010, 09:06 AM #9
Yup. I hope he asked you how much ballast you run. I found the lower pitch props didn't throw as clean of a surf wake but the hole shot is incredible.
06-15-2010, 10:00 AM #10Member
- Jun 2007
- 71
