Results 1 to 2 of 2
    Mar 2003
    s.e. washington state
    Default Popping from my subwoofer speaker
    I replaced the subwoofer amp this year and went from 250 watts RMS to 500 watts and I used the existing speaker wire and 10" speaker. I went out today and checked the system out an I get an occasional obnoxious pop when the stereo is turned up and when going from silence to heavy bass but when the bass is continous the speaker sounds fine. I have a Panasonic KAC-8105D amp and a MTX speaker that has been in the boat for at least 8 years or longer. I have a Kicker 12" sub in a box that I may try and see if that eliminates the popping along with adequate wiring. You stereo dudes (it used to be buffs) have any words of wisdom?
    1998 Mobius
    310 HP PCM
    Mar 2003
    Thanks for the feedback. I have a spare 12" sub on a shelf so I think I will connect that up and see if I have the same problems. I bought the amp last winter on Ebay and I have had good luck with buying there but my luck may have run out on this one.
    1998 Mobius
    310 HP PCM
