Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Quote Originally Posted by loudsubz View Post
    problem is I already included them in my trade in, and dealer can't swap with the roswell tower so my only option is to mod the roswell or remove and replace with something. If the quality of the 4 can setup is good I will just re-use the cans.
    Wheres the best place to buy the hollowpoints from?
    got it now.thought you still had the 8's
    Earmark's got them
    http://www.earmarkcaraudio.com/Xcart/home.php?cat=322
    May 2010
    Muskoka, Ontario
    hmm am I missing something? All I see is the 7.7 HLCD raw drivers on that site??
  3. #13
    Tooele UT....
    they don't list the raw drivers for the 6.5 inchers. call david and I bet he'll hook you up..
    you won't be disappointed with them. they are fantastic speakers and the service from earmark is great..
  4. #14
    Dallas, TX
    loudsubz,
    Those newer Roswell pods mount the speakers with a plastic ring suspended from the nose of the pod with a metal bracket. Its a very light-duty mounting system to suspend a much heavier HLCD.
    Also, while 6 1/2-inch HLCDs have the same 7-inch O.D. grill as standard coaxials, the interior basket size requires an oversized hole which will necessitate that you open up your plastic rings. The larger midbass motor structure may also conflict with the interior tapered metal bracket, not to mention fitting in the passive crossover board.
    Its hard enough for an undersized midbass driver to keep pace with a more powerful HLCD tweeter. But the challenge is compounded when the driver is in a very small displacement pod. Thus, you don't get the same midbass extension or tonal balance that you would from a HollowPoint 770 for example.
    You might consider upgrading your combo bar with HollowPoint 650 coaxials. Its the best sounding and most aggressive non-HLCD speaker I've heard and its pretty much a drop-in for your pods.
    The HollowPoint 650 HLCDs are now discontinued. We have two pair left. Bullet is out. And that's it.
    Good luck getting service parts for Krypt as their overseas source won't ship them product anymore.
    Earmark Marine
  5. #15
    May 2010
    Muskoka, Ontario
    thanks for taking the time to respond David.
    What is your take on those coaxials that are drop in?
    I came from a pair of KMT6 that I bought 2 years ago and they sounded good, but I could barely hear them while boarding, so if there comparable to them then I will pass.
    What about the kicker km6500.2 setup?
  6. #16
    May 2010
    Muskoka, Ontario
    David, when you said Bullet is out... do you mean going out of business?
    Also what is your choice for budget HLCD setups or am I going to be stuck paying for wetsounds etc.
    I agree on the Krypt parts issue as well, I think we all assume buying a pair of speakers means they are disposable if they break...
  7. #17
    Earmark Marine
    So that means that if you have service problems with the bullets 6.5 hcld that you bought within the year or the two you have left, you are out of luck with parts???
    Arkansas
    I have the 6.5 coaxials that i bought from earmark. I love them. They are crisp and clear and were a direct drop in to my roswell cans. I have the old roswell speaker/lightbar combo, though.
    Another note .. although these speakers sound excellent, i will likely be upgrading to HLCD when i decide to bite the bullet.
    You just have to decide how important the distant hearing is to you. I can hear mine at wakeboard distance, no problem, just not like an HLCD. In the boat they are as clear as can be. When the boat stops to turn around and pick me up i find myself wondering if the whole lake can hear what we are listening to.
    In summary, the bullet 6.5" coaxial is a great setup, especially if you dont want to bite the HLCD bullet (ha, no pun intended)
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  9. #19
    Dallas, TX
    loudsubz,
    Bullet HollowPoint is clearly an ongoing concern. Bullet has simply discontinued the 650 HLCDs and is concentrating on the 770 HLCDs. I agree with their decision relating to complete packages as the hang height is only 3/4-inch lower for about 40 percent more surface area and pod displacement. Its a big performance difference for a minimal cost increase.
    However, its not a particularly good thing for the raw retro market but that is simply too small of a portion of business to maintain this specific model.
    jmvotto,
    Bullet HollowPoint has an exclusive, continuing and positive relationship with their overseas builders. So diaphrams and re-coning materials should be available for years to come.
    Earmark Marine
