Results 1 to 10 of 19
    May 2010
    Muskoka, Ontario
    Default HLCD that fit in Roswell Cans?
    I am getting the 4 can setup and light bar with my 2010 LSV. What HLCD speakers have you guys installed with minimal or no modding at all? I don't mind cutting the cans to accept a wider speaker, but I'm more concerned with depth as I know the cans taper at the end.
    Jan 2010
    Portland, Oregon
    The bullet hollow points should fit in them. They are an amazing speaker! They sound great up close and like your at a concert from a far. Plus I think that they are the only speakers besides the new kicker that you can buy without an integraded speaker can.
    2005 Moomba XLV, Polk db651 cabin speakers, 12" Kicker Comp, Bullet 6.5" hollow points in Arial Double cans, fosgate amps.
    B reak
    O ut
    A nother
    T housand
    Lake Point UT....
    bullet hollowpoints fit the depth, but you do have to make some mods to the cans. the bullets have a little larger basket than the stock speakers. I had to take a jigsaw with a metal blade and cut the diameter of the opening 1/8" bigger then redrill new screwholes. took around 1hr(be careful as the aluminum mounting face only has a few welds to keep it in place. saw will tweak the metal if it bites). a good stereo shop should do the job for around 75bucks if you don't want to. the cans should be removed from the tower prior to cutting.
    my biggest complaint with the hollowpoints are the lack of an enclosure for the crossover board, so if you do go that route, make sure you put something behind the boards to keep them from shorting across the aluminum of the cans..
    May 2010
    Muskoka, Ontario
    Quote Originally Posted by stretch55 View Post
    krypt also make an HLCD in 6.5" that should drop in but I have not tested it. I have their 8" and they sound good.
    May 2010
    Muskoka, Ontario
    are you guys talking about the hollowpoint 7.7 or a smaller one?
    Jan 2010
    Portland, Oregon
    Quote Originally Posted by loudsubz View Post
    The smaller ones. The 6.5 hollow points.
    B reak
    O ut
    A nother
    T housand
    I think they are talking about the 6.5 because they would be a direct fit in the roswell towers.
    Best bet since you have the 8", if you cant cut them to fit, then sell them as new and get new cans for the 8" krypts. OR sell the 8"'s to Newty and buy the 6.5" to fill the cans and sell the kicker speakers...
    May 2010
    Muskoka, Ontario
    problem is I already included them in my trade in, and dealer can't swap with the roswell tower so my only option is to mod the roswell or remove and replace with something. If the quality of the 4 can setup is good I will just re-use the cans.
    Wheres the best place to buy the hollowpoints from?
    Jan 2010
    Portland, Oregon
    Conntact David at Earmark marine. That is where I got mine. They are great to work with!
    B reak
    O ut
    A nother
    T housand
    Lake Point UT....
    2nd earmark. they are easy to deal with and david will help you out with all your questions. super nice guy..
