Results 1 to 10 of 18
06-06-2010, 12:40 AM #1Senior Member
- Apr 2010
- 238
Smoke & high pitch noise, temp 180+
Towards the end of the day today I noticed a light smoke coming from the transom as well as a high pitch noise coming from engine compartment. Noticed the temperature between the 180-200 mark...called it a day.
Impeller?
Water Pump?
02' Outback LS.
Thanks,
Cody
06-06-2010, 01:32 AM #2
I'd definitely check impeller first. Easy to do and cheap to fix if that's the culprit. At least rule that out first. 3 bolts and you'll know right away.
Good luck!
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
06-06-2010, 12:14 PM #3Senior Member
- Apr 2010
- 238
That was my thought also. I will most likely pull this today and see what is going on.
06-06-2010, 07:10 PM #4Senior Member
- Apr 2010
- 238
pulled the impeller today..found the culprit!
It was torn up pretty good. Time for a new one.
Anybody have the part number for an 02' Outback LS?
06-06-2010, 08:14 PM #5Senior Member
- Apr 2010
- 238
below is a pic
06-06-2010, 10:37 PM #6
Yep,thats a bad one.
jy
06-06-2010, 10:56 PM #7
ok i have to ask...........when was the last time you replaced it and do you have a water strainer?
09 21v LAUNCH
99 Outback LS. Sold
Doug
06-06-2010, 11:29 PM #8Senior Member
- Apr 2010
- 238
I just purchased the boat over the winter. Not sure if the previous owners have ever changed it. We have had it out a few times this year with no issues. We had the dealer do a full inspection of the boat before purchase and came back with no issues.
06-06-2010, 11:53 PM #9
Easy find, Easy fix, Easy done
When it goes from FINE to starting to overheat with no other signs it's usually the impeller. Glad it was minimal. Back on the water in no time!
2015 "NOT A MOOMBA"
06-07-2010, 12:08 AM #10Senior Member
- Apr 2010
- 238
Thanks Viking, correct me if I'm wrong but I believe this is the impeller I need for my 02 Outback LS:
http://www.skidim.com/prodinfo.asp?number=RP061018
I will be back up and running by this weekend!
