Results 11 to 20 of 25
  1. #11
    Feb 2008
    Traverse City, MI
    It's your boat so you make it how you want it. (As long as it's OK with Dad).
    I call the shots here, he's just along for the ride (or drive, lol)!
    2013 Outback V
  2. #12
    Feb 2008
    Traverse City, MI
    Looks good and thanks for posting the pics. Doesn't look like you have plugs in the speaker cans yet for the speaker connections?? I like it so far. I have the OEM bimini and think it would interfere with the speakers mounted that way? But really creative.
    Yea, I haven't installed the gromets or plugs for the cans yet.
    2013 Outback V
  3. #13
    Ian,
    i got my krypts mounted in the similar area off to the side but hung from the tower. I had to go 6.5 do to the bimini.
    Did you thread the cross bar for the bolts?? or how di you get the nut in the cross bar.
    where did you get that type of loom, i like it..
    sorry for all the ?'s
    i will get better pics once back at the lake, but now the system is loud.....
    Feb 2009
    Seattle, WA
    look great ian ... nice job.
    2007 LSV
  5. #15
    Mar 2008
    Vancouver WA
    Looks great! I like the side mount.
    PWI as usual...
  6. #16
    Mar 2008
    Vancouver WA
    I have 3 sets of those cans and was wondering if the 8's would fit in there. Looks like they fit perfect! I'm really tempted to pick up two sets. Let us know how it sounds when you get them going.
    PWI as usual...
  7. #17
    Newty, the 6.5 's sound great but these are the first HLCD i have heard. My local dealer just got a WS display so i may take a listen to them for reference.
    I have them powered with aMandley kicker 450.2 and it sounds great. I assume the 8"'s will sound even better and four would really scream.
    MY .02
    Feb 2008
    Traverse City, MI
    Yes, I threaded the cross bar for the bolts.
    The loom is called TechFlex and I got it from this seller on eBay:
    http://stores.ebay.com/FURRYLETTERS
    Looks realy sharp man.
    Are you only using 1 bolt to hold that up? If so might think about a small pin the kind that are slit that you can sorta press in or double bolt those. I would think all the vibrations might wear it loose or maybe a lock washer will hold it tight. Just a thought.
    Yea, I need to figure something for that out. Right now between the tower and the can I have a star washer, and then a lock washer between the head of the bolt and the can. They seem really stable, but I'm still not convinced that they won't move. I'd like to run a second bolt or something through, but the suface area of the bracket is really small, so not a lot of room to work with. Still trying to figure that one out, lol.
    2013 Outback V
  9. #19
    Ian you could just swap sides with the speakers and have the mounting bar face up, instead of down, therfore the weight would keep it in place. just have to spin the grills so the krypt lines up. it should be centered on the speaker so height should be the same... just a thought
    Aug 2009
    Montana
    Is that the 1/8" stuff on the site?
    Might grab me up some.
    Thanx
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
