Thread: V-DRIVE light stay on and fliker
05-30-2010, 06:25 PM #1Member
- Apr 2010
- moncton, nb canada
- 60
I went riding the other day and notice that my v-drive oil light is on. I changed the oil in the engine and level is perfect. I checked the oil in the transmission and topped it off, now perfect. Checked the oil in the v-drive, topped it off also, now perfect. I know the light is suppose to stay on until a certain RPM. Sometimes its stay on no matter what rpm, then will go off or just flicker. Oil pressure is fine. temperature is fine. No noise except the belt that started to squeal lately. probably loose or something. will only do it when gear is engage, not in neutral.
Any ideas?????????
05-31-2010, 08:18 PM #2Member
- Apr 2010
- 60
anyone have an idea or had the same ??
05-31-2010, 09:27 PM #3
was your vdrive oil low? when was it last changed? what is the boat?
09 21v LAUNCH
99 Outback LS. Sold
Doug
06-01-2010, 06:09 AM #4Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Check the oil pressure switch on the v-drive.
06-01-2010, 07:01 PM #5Member
- Apr 2010
- 60
was your vdrive oil low? yes when i added some. now its full.
when was it last changed? last year from the previous owner. just bought the boat 1 month ago. oil has about 15 hours on it now.
what is the boat? boat is a 2003 Moomba LSV with 325hp indmar 350
maybee i should check the pressure switch too
