Results 1 to 8 of 8
07-21-2010, 10:24 AM #1
On a stock '06 LSV what are the two right switches for?
On a stock '06 LSV what are the two right switches for? I have a G3 so that's not it. Help '06ers!
06 LSV
2 - 750lb Fatsacks, Custom Sunbrella Cover and Bimini, Kenwood KMR440MU and Amp Bazooka Tower Speakers, Aerial Mirror, Stargazer, 4 Port Heater.
Toys - O'Brien Natural, CWB Pure, IS Yellow Loogie, CWB Ride, Hyperlite Voyageur for the kids.
07-21-2010, 11:11 AM #2Senior Member
- Jun 2010
- Lake Houston
- 656
Well on mine, the 2 switches all the way to the right are slightly different. The one ALL the way to the right is a 3 position switch, when you push the top of the button, my depth finder turns on. When its in the middle its off, and there is nothing connected to the bottom rocker. The switch just to the left of that on my boat is a blank 2 position switch, its either off or on. My particular boat doesnt have anything connected to this and I thinik this is just Moombas attempt to allow you to add things later. I will probably use this as a power source for one of my amps in the near future.
2013 LSV
2005 LSV - SOLD
07-21-2010, 11:48 AM #3
I was wondering why the depth finder comes on and off!
Do you know where the fuse is for the ballast pump, I can only find for the solenoids and the drain pumps06 LSV
07-21-2010, 11:59 AM #4
On mine...
My fuse block has both in and out on the same one. If you had pics I could help you on the switches question. I have the same boat....
07-21-2010, 03:43 PM #5
07-21-2010, 04:34 PM #6
Pictures this weekend
06 LSV
07-23-2010, 10:26 AM #7
First picture is of the fuse panel for the ballast - one side is solenoids, one side is drain pumps
Second picture is mystery box located behind the three ballast switches - anyone know what that is?06 LSV
07-23-2010, 10:53 AM #8
looks like the fill pump relay. have any pics of the front of the switches in question
