Results 1 to 10 of 16
Thread: Binding Lube?
    May 2007
    Naperville, IL
    Default Binding Lube?
    What do you guys use for binding lube, if anything? My son and I were both have trouble sliding into our new boots and I bought a bottle of foot slick at about $9 a bottle. Would a cheap biodegradable soap do the same job? Never had to worry about it before, but I'm sure somebody else has.
    Jan 2010
    North Texas
    I have a bottom of "Slime" from our local board shop, but before I had that we just kept a bottle of Dawn Hand Soap in the boat. It worked about the same, but the slime feels like it rinses off cleaner once you are in vs staying slick
    Pensacola, FL
    I buy the cheapest dish soap from walmart. Works great.
    Don't use it much now that I have Hinge Tech bindings.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Aug 2009
    Montana
    I've got some Moose Juice and then have the binding lube that came with my "bucket of babes" but haven't tried that yet!
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Mar 2003
    s.e. washington state
    I'm slimed here and I agree the dishsoap doesn't come off as well. I used to use a silicone spray with no issues.
    1998 Mobius
    310 HP PCM
    Apr 2010
    saskatchewan, canada
    use the cheapest shave gel or foam you can find. It rinses away way faster and easier than soap. I have tried everything you can think of and shave gel is by far the best and most economical!
    Des Moines, IA
    With the Ronix bindings I don't need it, but still keep some Moose Juice around for the older style bindings.
    St. Albert, Alberta, Canada
    Bought a bottle of Moose Juice from an exhibitor at the Water Ski Worlds in Calgary last year. It is far superior than either of the two brands I'd purchased from the local dealer previously.
    '07 Outback V
    Ski|Board|Surf|Skate
    May 2007
    Richmond, VA
    Found myself without binding lube, so used suntan lotion that was in the glove compartment. Worked fine. Normally have a bottle of Slime. Both work about the same.
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    Sep 2009
    Copperas Cove, TX
    Boot Butter
