Thread: Fuel pump
05-25-2010, 10:35 AM #1
Fuel pump
99 outback pumpm pn152875.
Anyone know if the Carter P4070 will work in place of the 152875?
Thanks.
05-25-2010, 01:30 PM #2
Not sure about the part number that you have there. That appears to be an automotive fuel pump. The part number that I have (I have not replaced one yet, but got the part number from another member) is Carter 180-P4389. It is described as a marine fuel pump.
Be sure to check yours against this one though. I have not bought one yet.
Here is one from a quick search, let us know where to find one cheaper!!!
http://www.summitracing.com/parts/CRT-P4389/
.Last edited by JesseC; 05-25-2010 at 01:36 PM.
15 Mondo Surf Edition
02 LSV - Traded In
05-25-2010, 03:43 PM #3
I had to replace mine two years ago ('99 Outback PCM 5.7L 350). This is what I replaced it with:
http://skidim.com/prodinfo.asp?number=RA080018
06-07-2010, 03:10 PM #4
99 outback pump pn 152875
I found the exact Carter pump I needed at Napa (Auto Parts) for $80.95. It has the same part number and is packaged the same as the Skidim model. I put it on and the boat's performance was much better. The old one had been failing for about a year. It is an auto pump and was used for a few years on some Camaro models.
I vent the cowling in the hotter part of summer and have not had any vapor lock issues since then. I remove the bilge cover on the floor for extra air flow, and sometime raise the cowling an inch or so to let more air in. I also lift the cowling and let the engine compartment cool off between runs.
Thanks for the reply.
06-07-2010, 09:32 PM #5
I just ordered a new one from Summit Racing. Carter P4389 Marine Series. It was $117 with shipping.
Make sure the one you bought is MARINE APPROVED otherwise your asking for problems.....
I alo bought some Thermo heat tape and wrapped the fuel lines with it to help prevent vapor lock.'99 Outback (Maroon/Creme) GM 350/Holley 4150
550 HRS
LaSalle-Peru, IL
