Results 1 to 6 of 6
Thread: Water Pump Impeller
05-19-2010, 08:46 AM #1
Water Pump Impeller
I do this every year and every year I get frustrated. I need to change the Impeller on my boat. Every year I have to take off the pump and the Impeller falls out. Is there a way to take it out without taking off the entire pump. I tried needle nose pliers and Nothing. Can someone tell me an easier way PLZ
TazzTazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
05-19-2010, 11:16 AM #2Member
- Jun 2008
- Bellevue, Wa.
- 31
Get an impeller puller and it will come right out. I use one on my v drive boat where the engine faces the stern and I can't even see the impeller, with no problems. I can get it out in about a minute.
05-19-2010, 05:27 PM #3Junior Member
- Feb 2009
- 4
Same here. Used a puller the last two years on a V drive and it works great. Also the impeller is not damaged. I now have two spares. Takes more time to get the new one in.
05-19-2010, 05:47 PM #4
Tazz,
Did you try needle nose vise grips? The jaws stay parralel allowing you to get good bite. I insert one jaw in the middle of the impeller and the other between two impeller vanes. Then I wiggle it out a little, release it, insert the vise grip a little further, wiggle it out some more, readjust it, and it's out. Takes me no time at all.
I also spray silicone lubricant into the impeller housing and bump the engine for a sec to spread out the lube before I start. I do this at winterizing time.
AlAl
05-19-2010, 10:31 PM #5
tazz
take the support arm off the pump, but don't unbolt the pump. will allow the outer area to spin.. grip the impeller with pliers and and rock the housing and forth.. werks fer meBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
05-21-2010, 04:17 PM #6
I've always used the metal paint can openers. usually just one works fine. Stick it in, it hooks the back of one of the splines, pull it out. I've never had a problem with this method and the impeller doesn't get ruined (as with needle nose or other pliers) so it can be kept as a spare.
We are eternal, all this pain is an illusion.
