Results 1 to 9 of 9
Thread: Left rear bag won't empty
05-18-2010, 11:48 PM #1Junior Member
- May 2009
- Coeur d'Alene, ID
- 8
Left rear bag will not empty
I have a 2006 outback V. Left rear will fill but will not empty. Any suggestions? Fuses are fine.
05-19-2010, 04:10 AM #2Senior Member
- May 2008
- Seattle, WA
- 104
05-19-2010, 07:30 AM #3
does the pump come on-can you hear it?
if so is there something blocking the hoses so water cant pass?
if not, check to make sure you have power to the pump-simple test light.
try swapping it with one of the other pumps is another simple testHey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
05-20-2010, 09:24 PM #4Junior Member
- May 2009
- Coeur d'Alene, ID
- 8
Thanks, it does not empty at all. The pump does not come on at all. I will do some more testing. I appreciate the help.
05-20-2010, 10:03 PM #5
05-20-2010, 10:19 PM #6Member
- Aug 2009
- montreal
- 40
I had the same problem last year, I noticed that one of the wires under the dash was disconnected from the ballast motherboard. Most probably from a road trips or impacts from the waves on the boat. A small board with 6 orange wires connected to it.
My problem was cause because the wires were too tight ....The factory which build the boat, screwed in the motherboard for the ballast in a place that cause to much tension on the wires...So when there was a large impact on the boat. Pop, one of the wires would pop out from the board.I could not empty my ski locker ballast no more until I replug in the wire.
This year, I unscrew the ballast motherboard and replaced it where there was less tension on the wires.
I hope this helps.
05-21-2010, 11:30 AM #7Senior Member
- May 2008
- Seattle, WA
- 104
At the beginning of last year all of my pumps were not working. Come to find out all the fuses were blown. Replaced them all and everything worked again. Simple and cheap fix.
06-02-2010, 08:46 PM #8Junior Member
- Oct 2007
- 21
Same issue as 4fish4. The wires were disconnect on the ballast motherboard under the desh. I spliced the wires to make them longer. Problem solved. Thanks Skiers choice for saving 2 cents per boat with shorter wires.
06-03-2010, 11:02 PM #9Junior Member
- May 2009
- Coeur d'Alene, ID
- 8
Replaced the pump and everything is back in action. Quick, easy and cheap fix. Thanks to everyone.
