Results 11 to 20 of 21
05-19-2010, 12:28 PM #11Junior Member
- Sep 2008
- 19
yes they are normal 3/ or 1" pipe thread,ebay my brothers
http://cgi.ebay.com/3-4-Electric-Sol...item45f28d4409
it may just be easier to use one of the switches on the consol that are not being used to activate tyhe solinoid then try to tie it in with all three fill switches.i ordered one yesterday i am hoping to have ity installed by the end of next week with results shortly there after
05-19-2010, 12:35 PM #12
Thanks! The 1" says 24v how woould I run 3 of these? I would want to replace the manual valve on my 3 intakes. I think this would eliminate the need of the 1" vented loops and creat an even faster fill time since it would reduce friction in the fill lines.
2023 Moomba Mojo
2013 Malibu VLX 21 - SOLD
2005 Moomba XLV - SOLD
2001 Supra - SOLD
1998 Master Craft - SOLD
05-19-2010, 02:50 PM #13Junior Member
- Sep 2008
- 19
i thought that they all used the same intake on the bottom of the hull???i know that the rear bags for certain use the same intake,and i just assumed the front used that ipne as well,do to the fact that there are only 2 intakes on my hull,1 for the drivetrain and 1 for the ballast pumps?
05-19-2010, 02:58 PM #14
I posted the wrong one. I found the 12v ones. I still need 3. 1 for each intake, I have 3 intakes, 1 for each bag. I think I could just wire them in with the tsunami's and add a bigger fuse. Then I should be able to remove the vented loops. I am just waiting for Jason at wakemakers to confirm that.
2023 Moomba Mojo
2001 Supra - SOLD
05-19-2010, 03:28 PM #15
You are correct - the stock set up has one intake feeding one pump then three sprinkler valves that determine where the water will go. Are you going to upgrade your ballast to three separate pumps off one intake and do away with the sprinkler valves? I assuming you are since you ordered this valve.
Stretch has upgraded his so that each bag has it's own fill pump and each fill pump has it's own 1" intake.
stretch,
Yes, you could do what you are proposing. But look at the cutaway diagram in the listing (click on item 10 in the technical specifications section) and the pic of the bottom part of the valve. I count 5 times that the water has to turn 90 degrees before eventually going out the other end so it looks like a very restrictive design. I think you would get better flow out of your Irritrols.
danimal,
Could you do a flow test for us when you get the valve? This is how I suggest you do the test. Disconnect the 1" fill line going from your Rule pump to the sprinkler manifold. Attach a reducer hose barb to the 1" hose - 1" to 3/4". Can get at Home Depot or Lowes for like 50 cents. Disconnect one of your rear fill lines at the sprinkler valve and remove the quick connect. Attach the hose to the reducer hose barb. Disconnect the other end from the sac and drape it over the back to the swim platform. Get a large cooler and time how long it takes to fill the cooler. Then install the valve at the end of the hose (you will need to get a fitting from HD again - 3/4" threaded male to 3/4" hosebarb) to attach the valve to the hose. You will need to run power to the valve to make it open. Time how long it takes to fill the same cooler and then let us know. Or send it to me and I'll be happy to test it out
Thanks!
AlAl
05-19-2010, 04:11 PM #16
05-19-2010, 05:45 PM #17
05-19-2010, 07:31 PM #18
05-19-2010, 07:33 PM #19
05-20-2010, 08:35 AM #20Tazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
