Results 1 to 10 of 11
    Jan 2010
    Portland, Oregon
    Default what battery or batteries???
    I have dual batteries. The are both deep cycle marine duralast's. But if we beach and shut the boat off I turn the perko on to battery #2 for the stereo and the battery dies after 2 or 3 hours. I was thinking of upgrading to optima's. Is that a good choice or is there something better out there? I don't want to drop $600 each on the stingers even though I am sure they would outlast any battery out there. Just to much money...
    2005 Moomba XLV, Polk db651 cabin speakers, 12" Kicker Comp, Bullet 6.5" hollow points in Arial Double cans, fosgate amps.
    B reak
    O ut
    A nother
    T housand
    De Pere WI
    don't have any real world experience on the optima's, but have heard that they are a lot of hype for the name in the marine environment. perhaps replacing with 3 good interstate deep cycle and wire 2 of the batteries to show a 12volt load for the stereo?
    on a side note, looks like we have a similar stereo. what fosgates are you running? I have not used their stuff for 15 years and put 3 in this winter and man, do they rock...
    Stretch i got the solution for you sir. Give me a call or a text when you get time. I can get ya hooked up man.
    Aug 2009
    Montana
    Well why not post for the good of all - "secret man"
    (JK)
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Mar 2003
    s.e. washington state
    If you want storage capacity and you have the room and can take the weight then two 6 volt golf cart batteries is the answer. They put any pair of deep cycle batteries to shame. It is the battery of choice for RVs. I run everything in my RV for 9 days without a recharge.
    Trojan T-125's
    488 minutes@ 25amps
    240 amp/hrs
    1998 Mobius
    310 HP PCM
    Sep 2009
    Copperas Cove, TX
    Look at the Deka Seamates. The group 31 is 105 amp hours and the group 27 is 96 hours I believe. I have 3 Deka batteries in my boat. They run about $160 for the group 27 each and about $195 for the 31's
    Mar 2008
    Vancouver WA
    +1 on the dekas, I'm really impressed with the ones I have.
    PWI as usual...
    Jan 2010
    Portland, Oregon
    Quote Originally Posted by zabooda View Post
    Trojan T-125's
    488 minutes@ 25amps
    240 amp/hrs
    So can I run just one 6v battery in my RV or would I need to run 2 so I can show 12v? I was thinking of pulling the battery out of my RV (it's a Trojen, group 27 I think) and putting that in my boat and just putting a 6v in the Rv. So can i do that or do I ned 2 6v or a special charger?
    B reak
    O ut
    A nother
    T housand
    (JK)
    Last i herd from Brian at Exile is hes got a contract with once of the big Gell Battery companies and can get them shipped in. I was going to check with Brian for Stretch. After me and him talked he decided he didn't want to spend that much on batteries and i don't blame him.
    Feb 2009
    Seattle, WA
    audioforce 1100
