Thread: Temp Gauge Falls Through Dash
05-11-2010, 02:24 PM #1Junior Member
- Aug 2008
- 2
I have a 2005 Mobius XLV I purchased new.
About 2 years ago the temperature gauge broke free and fell backwards through the dash. Investigation shows that the dashboard material holding that gauge is very thin and fragile and has cracked.
Of course, its a very bad idea to be without a temp gauge, so the gauge current lives propped up on the outside of its proper home.
Any tips on a good way to reinforce the dash and fix this issue? Is this common?
05-11-2010, 08:40 PM #2
If this was on my boat i would go with Rubber Cement. Coat it on the gauge and slide it in the space it was in. The cement will harden and fill in the gap, this will then look factory again. This will also still be soft enough to remove the gauge if needed at a later date.
RTV sealer will work very well also but is a much more permanent route.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-12-2010, 12:49 PM #3Junior Member
- Aug 2008
- 2
Thanks. Sounds like a good idea. I'll give it a shot.
05-12-2010, 01:40 PM #4Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
I would pull the dash apart and fiberglass the broken/weak area. Then I would re-drill the hole and reinforce any area I had concerns about. Of course, this would take me a week and that is not a good thing in the summer.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
05-12-2010, 01:47 PM #5
