Results 31 to 40 of 49
Thread: Nasty Mat ~ Part II
05-13-2010, 11:31 AM #31Senior Member
- Oct 2009
- 102
I actually got my whole left side & head down into the locker when I was running my amp wires to the other side. I had the boat in the driveway with the nose angled down so this allowed all water to run to the front of the the boat. I hadnt had the boat out since last year so there was no water in the engine compartment but when I leaned into the ski locker and put my weight on it I noticed a small upward flow of water coming into the front of the locker. So A) there is either a drain up there or b) the ski locker floor has a crack/hole in it & allows water to drain into a lower section of the boat. This tells me that it is going to be virtually impossible to get this water out & keep it from getting in there unless I seal that locker floor off some how. Bad design and no way to access it!!!
05-13-2010, 11:44 AM #32
What if I install a hidden tube that goes right to the bottom? I wonder if I could suction it out with the shop vac.
05-13-2010, 11:50 AM #33Senior Member
- Oct 2009
- 102
Then my question would be how are you gonna get the tube to the bottom? Where I saw the water flowing from was all the way at the front of the locker & I couldnt see how big the hole was or put something down it if I wanted to. If you have another idea of how to access this lower section of the boat let me know.
05-13-2010, 12:00 PM #34
May have to drill a hole.
05-13-2010, 12:11 PM #35
I also don't really see a purpose for the bag, besides pading for if you do use it as a ski locker, or to help water drain off of wet things. Though, with the small lip that is before the hole in the locker, it still would prevent all the water from excaping. I like the pad in there, I just don't want it to be all stinky and smelly. I'll try to 5 gallon bucket trick this weekend and see if I can get it smelling fresh. I think I'm also going to try to plug the drain hole, just to see if that helps at all. If water is coming in from a different source, then, well, it's a moot point. But at least I can say I tried!!
2015 Supra SC400
08 LSV - Sold
Go big, or go home.
05-13-2010, 03:31 PM #36
05-13-2010, 03:55 PM #37
05-13-2010, 09:37 PM #38
I haven't had an issue yet with the smelly mat but I always remove my ballast bags and the mat after each weekend.
05-16-2010, 06:40 PM #39Member
- Apr 2010
- moncton, nb canada
- 60
same problem here with the water. mine was under the ski locker area. Cut a hole with the hole saw and put a gaz cap like plastic cap. there was about 2 inch of water underneath there. water was seeping through 2 holes that are made from factory to inject the foam in the hull. Now i just have to unscrew the cap take out the shop vac and give it hell. works like a charm.
05-17-2010, 10:57 AM #40Senior Member
- Oct 2009
- 102
