Results 1 to 10 of 12
    Feb 2010
    Appleton
    Default New 14.25 inch prop trailer clearance
    Well here is the deal guys,
    Just had the dealer put a new prop on cause the one that was on the boat when we purchased it had some serious vibration issue's, none the less we had them put the larger (14.25 ) i think thats the proper measurement prop on.
    When I checked the clearance on the trailer for the prop gaurd it is really close and I am wondering if I should modify my trailer or what routes I have to not worry, my biggest fear is obviously hitting the prop on the trailer while loading. Also I usaually power load due the weight of the 23ft of boat ...
    So the 2 answers i am really searching for are:
    Do i need to mod my trailer >?
    To power load or not to power load >?
    Any info would be greatly appreciated
    never enough ...
    2005 Mobius XLV
    Jul 2002
    London Ontario Canada
    first off how much clearance do you have?
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Feb 2010
    Appleton
    I would say with the boat on the trailer strapped down less the .5 inch
    never enough ...
    2005 Mobius XLV
    Aug 2009
    Montana
    here's a thread on the subject.............
    https://forum.moomba.com/showthread....prop+clearence
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    I might think about raising the back end of your bunks 1/2". Can't imagine that would wreak too much havoc with anything else.
    Feb 2010
    Appleton
    Yea, either that or re fab the guard i havent decided yet ... I am thinking shiming the bunks will be much eaiser but I will have to look at it tonight when I get home.
    never enough ...
    2005 Mobius XLV
    That's where I'd start-- just be careful to use wide enough shims as they will press into the wood if they are too small (like washer size).
    I'm having a clearance issue on my 21v. I contacted Boatmate and they had a simple solution and this is the shim kit they sent...
    '05 Supra 21V Launch
    Feb 2010
    Appleton
    Hey ssmith,
    what did that run you for cost ? And am i seeing correctly thats plastic right ?
    Also all said and done what was your prop clearance after you installed the shims?
    thanks for the post !!
    never enough ...
    2005 Mobius XLV
    Quote Originally Posted by aook23 View Post
    Hey ssmith,
    As for the shims yes. Its a HDP type plastic. AWS Shimmed my front bunks because on the trailer you could put your whole hand between the bunk and hull. This caused the nose of the boat to hit the roller all the time. They just unbolted the bunk shoved those in and rebolted it.
    [COLOR="#696969"]
