Results 1 to 8 of 8
Thread: Nose crack
    Nov 2008
    Default Nose crack
    Luckily not mine.. I was trying to get a little air last night, and the board shot out from under me and slammed into the boat. It's got a decent sized crack now in the nose.
    Any tips on how I could repair this? It's a Walzer Alpha board, which is a little fragile. Is there some type of sealant that hardens?
    Apr 2008
    California
    I would say epoxy would be the repair of choice. My Shredd Stixx was backed into and hit by the swim platform (No i didn't do it) while leaning ahainst the wall and cracked about 6" down from the nose tip. Epoxy fixed it just fine and still going strong two years later. It will not match however and that you'll have to live with.
    Nov 2008
    Thanks Razz, I'm not concerned w/ the looks necessarily, so that sounds like that'll work for me.
    Wondering if I should throw a nose guard on there. Does anyone use one and does it actually do any good?
    Apr 2008
    California
    Mine has one on it and it does help. Mine is installed so that it's not full against the board, there's actually about a 1/2" of slack for it to absorb a hit.
    Aug 2006
    I fixed a ding in my LF Venture with epoxy.. it was on the side and I dremeled it out and built it up with Epoxy, then sanded it back flat. works great. i painted over to "TRY" to match"
    worked great.. '
    most important thing is you want to seal it so water does not keep getting in
    Brad
    Mississippi/Louisiana
    2011 Launch 21V
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Jun 2009
    Middleburg, FL
    I fixed a CWB ride with Marine-tex epoxy. Comes in white or grey.
    '09 OBV
    May 2007
    Richmond, VA
    Question
    Quote Originally Posted by csm View Post
    Okay, so I'm not a wake boarder and, therefore, maybe I'm missing something here. Assuming you are riding a 75 foot line, how can your board possibly hit the boat when you get some air?
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    Holt MI
    Surfboard Deerfield... hitting the boat on a wakeboard would have to be some kind of record
