Results 1 to 10 of 17
    Dec 2006
    Tigard, Oregon
    Default Removing Ballast Intake Thru Hull Insert
    So I started removing the stock ballast stuff in preparation for my upgrade. I got the stock pump off, then then the shut off valve, then the elbow so now I am at the thru hull. My thru hull intake is 1" diameter with a 3/4" diameter threaded insert. I am trying to remove the 3/4" insert without removing the whole intake as I am going to use the existing 1" intake. I tried locking vise grips on the threads of the 3/4" insert (yes, damaged the threads a bit but doesn't matter) with a short cheater bar on the vise grips but it will not budge.
    Any ideas how to get it off? Below is a pic.
    Thanks,
    Al
    Al
    Apr 2007
    Las Vegas, Nevada
    I thought that it was one piece. That is why I removed it and changed it out with a real 1" fitting.
    Nov 2003
    Land O Lakes, Florida
    Al, its one piece, your going to have to remove the whole thing.
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Des Moines, IA
    Yep, it looks like an insert but it's not. It's one solid piece of cast bronze.
    Dec 2006
    Tigard, Oregon
    Well, no wonder it wouldn't budge! Wonder why it's made that way instead of just one continuous 3/4" piece?
    Thanks for setting me straight!
    Al
    Al
    Feb 2006
    Birmingham
    Well, look on the bright side, the hole is already large enough for the new 1" thru hull!! No drilling. I figure they did this so that you only had to drill one size hole in any boat whether it required a 1" or a 3/4" probably a shortcut for the boat manufacturers.
    15 Mondo Surf Edition
    02 LSV - Traded In
    Dec 2006
    Tigard, Oregon
    Need your help again guys. I've removed the big nut around the 1" threaded pipe and have removed the 4 screws (actually, mine only had three) on the scupper from underneath the boat but for the life of me, I cannot get the fitting to break loose from the hull. I've tried beating on it from the top, first with a rubber mallet, then with a small sledge with a piece of wood on top of the fitting to finally, hitting the top of the fitting directly with the sledge to try and break it loose. The thing just won't budge. So what's the trick to gettting this thing off?? I'm afraid of hitting it much harder for fear of breaking something.
    Thanks,
    Al
    Al
    Jan 2010
    Portland, Oregon
    Thanks,
    Al
    The Marine sealant just has it "stuck" in there. I beat mine like you did and it poped out. Try to cut around it, in between the through hull and the actual hole in the boat to try and break up that sealant. Or poke a flat head screw driver in that area to break up the sealant. It will pop out. It's just being stuborn! LOL
    2023 Moomba Mojo
    2013 Malibu VLX 21 - SOLD
    2005 Moomba XLV - SOLD
    2001 Supra - SOLD
    1998 Master Craft - SOLD
    Dec 2006
    Tigard, Oregon
    Well, I got it out. I cut the sealant around the hole but what did it for me was that I stuck a socket extension inside the pipe and pushed it forward. Hard. That broke the sealant loose on one end and then it was easy after that. However, a small piece of the gelcoat stuck to the scupper and broke off and now I can see the fiberglass strands from under the boat. I guess I will cover that with sealant. Also, remember that I wrote that the scupper only had three screws? Well, that's because whoever installed the scupper broke the head off the 4th screw and just covered it up with sealant. Nice.
    So how do I get all the old sealant off? Is there something I can use on it like goof off that will soften it without damaging the gelcoat?
    Thanks,
    Al
    Al
    Apr 2007
    Las Vegas, Nevada
    Good Job Al. I can not remember what I used to take off the old sealant. Are you just replacing that one scupper? or are you adding more Scuppers or Thru Hull Fittings? If your adding, did you go to Home Depot and purchase the 1" carbide hole saw. That is the only tool you will need to cut into the fiberglass. If you are adding Scuppers, make sure to drill pilot holes for the screws. I think that is why the head broke off on your scupper.
