Results 11 to 17 of 17
Thread: ski racks
05-07-2010, 10:15 AM #11
05-07-2010, 11:24 AM #12
Same tower as mine, and the Roswell fit just fine on the "vertical" bars. It's not clear in my previous picture, but the the ski rack is between the "upper" horizontal bar and the top bend.
2008 Outback V black
05-07-2010, 09:01 PM #13Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
The board rack already installed on the boat can be moved to the lower bar and spread out further apart and then a ski will fit in . I have one rack for skis and one in the original spot as is for wakeboards. If his ski is double boots it can still be done with ski just not centred but still works.
05-07-2010, 11:20 PM #14
05-08-2010, 12:09 PM #15
on the lsv they mount it on the lower bar so i might play around with it and see if i can make it work on mine then just look for a wake board rack as that seems like an easier task to do. we will have 2 to 4 wake boards most everytime we go out so can't just do away with the one side
08 lsv all red- dual battery system, kicker 700.5 and 450.2 amp, 10" kicker sub, wetsounds eq, polk db651 cabin speakers, exile xm7 tower speakers, ss thru hull fittings, seadek pad, evolutions cover
https://forum.moomba.com/showthread.php?t=10664
05-08-2010, 11:41 PM #16
Gus, I bought the Monstertower ski-rack. I am out fishing for Halibut right now and am on my Blackberry. For some reason it won't let me send a PM. As soon as I get it I'll post pictures.
2007 Outback V
05-09-2010, 04:11 PM #17Senior Member
- Jun 2007
- 926
I just clear the guides when doing loading and unloading . Just be carefull and watch for loose strings etc.
