Results 1 to 10 of 11
Thread: Gas Gauge
    Apr 2004
    Bismarck, North Dakota
    Default Gas Gauge
    I was wondering if there is anything that can be done for the gas gauge on my 04 Outback. When the gauge shows it is running on empty the most I have gotten into it is 16 gallons. Is there any adjustment for the float level? I know it is better than if it was showing half a tank and I ran out but to be off by 12 gallons!!! This is a little rediculous. I am also a little curious about Skiers Choice monitoring this site. I have posted three basic questions and havent gotten a resonse from Brian Raymond yet!
    Jan 2003
    Clermont, Florida
    Default Replying to Topic 'Gas Gauge'
    I can picture Ed G. bristling as we speak ......care to field this one, Ed?
    Oct 2003
    Northern Kentucky
    Mine does the same thing. Have learned that at about 6 hours, time to fill up, and usualy get about 25 gallons in then. Still plenty left, but better safe than sorry.
    Jun 2003
    Louisville
    I've never seen a very accurate boat fuel gauge but they should work better than they do. If itís imperative to know exactly how much fuel is left in the tank and you have given up on getting a reliable sending unit, a $100 fuel flow meter would solve your problem. You reset the meter when you fill up and it will tell you to the ounce how much fuel has left the tank since the last reset. If you program the capacity of your tank into the meter it will also tell you how much is left in the tank. However, if you forget to reset the meter on a fill up the meter would be virtually useless.
    2006 Outback V
    ED G does your boat normally run at 140 degrees? My dealer said that i have a 190 degree thermostat and my boat normally stays about 180 degrees. I have a 2004 LSV with the 320hp EFI motor. I also have a water stariner and am amazed at the stuff it picks up that could be going through the motor. About every 5 to 10 hours my filter is full of mud! It is muddy near my dock, but the rest of the lake is deep.
    Brent Burtrum
    Guest
    I also have a 04 LSV and it runs at 180 degrees. When the tank shows empty I have about 10 gallons left. I have a 29 gallon gas caddy so it works out ok.
    Hi Ed G--
    I was wondering what brand/type of water filter you purchased and where it can be purchased. You see, I fried a perfectly good engine, less than an hour after purchasing my 2000 Kanga w/94 hours; therefore, a filter on the intake was my top priority. Unfortunately, I'm not turning up many options.
    The closest thing I've found are irrigation filters. A conventional home water/sediment filter is too fine, bilge/pump filters are often too narrow (1/2" inlets, etc).
    After looking at literally dozens of stores and asking 20+ marine technicians about "inline" filters that would be (a) easy to change/clean/empty (b) allow high flow rates (c) allow primed flow-through -- primed/water-holding so that the impeller wouldn't burn out while initiating the flow (d) possibly clear, so that I could see when it required cleaning (d) not too big to fit in-line between the intake and the Transmission Oil Cooler ... The only thing I came up with are suggestions for irregation filters.
    As we speak I am awaiting a quote for a "Rainbird RBY Commercial Filter" with 1.5" inlet/outlets with a 30 Mil screen. This is the best I've turned up so far, but I would prefer something simpler if it exists.
    I am very eager to hear from someone who has successfully implemented a filter.
    Thank you in advance,
    -Rsuten
    Thanks Ed!
    I wish I had that option. Moomba won't sell directly and I don't have a local dealer.
    Can you give me an idea of what it looks like? Is it a clear, vertical tube (similar to a conventional water filter), or some sort of in-line apperatus like the disposable fuel filters? Do you have any idea what mesh screen it utilizes (e.g. 20,30,50,100)?
    Thank you,
    -Rusten
    Jun 2003
    Louisville
    Just do a search on 'inboard raw water strainer' and dozens of options come up. Here is a link to one sold by BOAT US:
    http://www.boatus-store.com/webapp/w...roductId=13426
    2006 Outback V
    Excellent - thanks for the tip. This is exactly the type of thing I was searching for, but couldn't find due to the incorrect terminology. "strainer" v. filter appears to make all the difference in the world!
  1. Ballast Gauge
    By Pike in forum General Chat
    Last Post: 04-17-2007, 07:52 PM
  2. RPM Gauge not working
    By 98outback in forum Service & Repair
    Last Post: 01-22-2007, 11:13 PM
  3. Gauge diameters
    By mvd in forum General Chat
    Last Post: 12-08-2006, 05:57 PM
  4. Temp Gauge Too Hot
    By in forum Service & Repair
    Last Post: 06-27-2006, 12:51 AM
  5. RPM Gauge
    By Danny in forum General Chat
    Last Post: 04-18-2003, 05:52 PM
