Results 1 to 10 of 15
    Aug 2006
    Default Boat Lift Setups?
    Any of you who put your boat on a lift, Can you provide guidance on how your lift bunks are set up? Angled in towards front?
    By chance, anyone with an LSV have an idea of width of bunks? Front/Rear?
    My first time with a lift.. So I am hoping to get the set up right the first time!
    Brad
    Mississippi/Louisiana
    2011 Launch 21V
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Feb 2010
    Nixa MO
    If you have a trailer, measure the bunks on the trailer. The bunks should be at least 17" high to clear the prop. Slowly walk your boat on the first time then set up lines that hook to the lift and the boat in the same place everytime. Then you either push the boat back or forward until the lines stop the boat so the boat sits in the same place everytime. You can also look at the trailer to see where it sits in the back to use that as a guide.
    Oct 2007
    Panama City Florida
    I wish I could help you but the boat is sitting in the lift. The bunks are straight and the company that put it in has years of experience here in Panama City. There are so many types of boats here that they know what they are doing with inboards and all other drive systems. I did have them use a plastic/rubber type of bunk material to cover the wood and not the normal carpet people around here use. It has a couple large round ridges that allows dirt to be washed away and not captured in the carpet when the bunks are sitting on the bottom.
    Jul 2002
    London Ontario Canada
    Ok , i put my own lift in 10 yrs ago when the custom lift guys came and it seemed like it was their first install. First it all depends how far apart your your cross I beams are and where they are picking the boat up. Mainly on the rear as you have to clear your prop shaft. The front has to be in front or behind your fins. My lift is in about 14 " of water at the front I beam and 24" at the rear I beam . So my tolerances are tight. I first set it up for a Outback DD and now have a supra21v on it.
    As you can see its sitting on 2x8 pt wood, I beams are 10 feet apart. fins are behind front Ibeam, but i need enough clearance for the beam to clear the front hull v on the boat. the back beam clears the drive shaft . If i dont get the back beam low enough the fins sometimes hit it as i pull the boat out. I have rubber in the front beam just in case its not low enough and the keel hits it going out.
    I have rubber cushion on the 2x8 so silt and sand doesnt gather on them. The front is angled in about 15 degrees and the rear close to vertical. The 2x8 twists ,a 2x 10 would be difficult to twist like that. I've kept my boats on it for the past 10 years with no probs and store them on it in the winters. my boat is only in the water when i'm using it, even if i'm not using it for a few hours it goes back on the lift.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Aug 2006
    MOseley, I had the guy I'm buying lift from increase the height of the bunks with New poles to raise it higher.
    I"ll probably have to end up playing with different widths.. I'll start with Trailer bunk width.
    Brad
    2011 Launch 21V
    2004 Outback sold
    Brad, I too went through this two years ago.
    Here is a link hope this helps
    https://forum.moomba.com/showthread....ighlight=bunks
    Aug 2006
    Thanks Joe
    Dock goes in May 16.. should have lift in that day too!
    Brad
    2011 Launch 21V
    2004 Outback sold
    Sled491 Guest
    Outback, I take it you've finally found a home?
    The big thing with a lift is to find a point of reference so that every time you drive on you stop in the same place.
    Thanks Joe
    What are you waiting for, ours went in april 10th lift may go in this weekend or next. My waders sprung a leak, thankfully i was prepared and had my wetsuit on under it
    Aug 2006
    Sled,
    WE rented a place on the lake. And then days later got a contract to sell our home! YEAH.
    Joe,
    The dock is a community dock and They will put it in on the 16th. Moving out of Miss this weekend and unloading in NY next weekend.. so the 16th will be the first I can use it anyway!!
    Brad
    2011 Launch 21V
    2004 Outback sold
