Results 1 to 6 of 6
    Jan 2010
    Portland, Oregon
    Default Ballast Upgrade time!!!
    Ok well after talking to Al a couple time this weekend and last week. Sounds like we are both getting ready to dive into upgrading our ballast systems. I am going with 3 1" intakes, 3 Tsunami 1200's, all 1" hose lines and 1" vented loops. I am leaving the drain alone for now, well I mean the pumps. I am on the fence with the "Y" and one way check valves for the drain side. Hopefully I will purchase everything Monay and go to work. I was really going to go with the signle intake and 3 tsunami 800's but if I upgrade to the 2300lb gravity 3 system I would like to have the faster fill time of the 1200's.
    2005 Moomba XLV, Polk db651 cabin speakers, 12" Kicker Comp, Bullet 6.5" hollow points in Arial Double cans, fosgate amps.
    B reak
    O ut
    A nother
    T housand
    Sounds like a good system man. I have to say yesterday waiting on my 750s to fill it sure felt like a long time compared to normal. I kept checking them and they weren't filled yet LOL.
    Got them filled and man was the ass saggin in the water. I had water half way up my calf haha. My puppy swam right up on the swim deck, he liked it LOL.
    I will be working on a system very similar to you and Als. Just got a lot of other things im supposed to be doing.
    Sep 2009
    Copperas Cove, TX
    I'm going to upgrade my system as well with 3 intakes and 3 Johnson reversible pumps
    Johnson reversible pumps? Are you going to use them to drain also? Or is that just the way the pumps you want are featured?
    Sep 2009
    Copperas Cove, TX
    These pumps seem to be more reliable, do not have any impellor issues, and flow 13.7 gallons per min which is more than the Jabsco. Also, slightly less expensive. Guys in the Centurion forum are filling 750 sacs in barely 6 min and doing 1100 sacs in 10 min
    If you spend the money on a reversible pump you definitely want to use it for both filling and draining. That will also simplify the installation as well.
    WakeMAKERS | WakePROPS | WakeSOUNDS | EasyBoatCare
