Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 64
  1. #41
    Dec 2006
    Tigard, Oregon
    Quote Originally Posted by GeauxTigers View Post
    So far so good. I have to go to HD and buy the valves that you put in. As far as the pipe joint compound, what exactly did you buy?
    It's just called pipe joint compound. Comes in a little can with a brush built into the lid. Real nasty stuff so don't let it get everywhere
    Al
  2. #42
    Dec 2006
    Tigard, Oregon
    How's the install going?
    Al
  3. #43
    Dec 2007
    Virginia
    I have everything mounted EXCEPT for the hot tubes. Bought a 4" hole saw yesterday.
    We have been running around trying to get soccer tryouts, gymnastics finals and year end school stuff done and I have not had time to work on it. I also bought a piece of pipe and a hose attachment to make a fake lake straight into the Vdrive intake like someone had shown on here. I will probably get it tested later this week. The part that kills me is that we are taking off to Hawaii for two weeks this Sunday so I will not be on the water until July 3rd after I get back.
    2007 LSV - All red
    Wetsounds PRO 80's WS420 Eq
    Acme 1433
  4. #44
    Dec 2006
    Tigard, Oregon
    Don't expect any sympathy from us
    Al
  5. #45
    Dec 2007
    Virginia
    LOL! None expected....
    2007 LSV - All red
    Acme 1433
  6. #46
    Hawaii? Waaaaaaaaaaaaaa!!!!!!!!!!!!!!
    Sep 2010
    alberta
    Default winterize
    Now how do you winterize your heater system?
  8. #48
    Dec 2006
    Tigard, Oregon
    Quote Originally Posted by 162cat View Post
    Well, this will be my first time winterizing it but I plan to disconnect the supply and return lines at the engine and then using either my air compressor or my 120V tube pump, blow the water out of the line.
    Al
  9. #49
    Aug 2009
    Montana
    I beleive you can just run a mixture of antifreeze through your engine as well and it will circulate through your heater Depends on which way you want to winterize? Some do both!!
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
  10. #50
    May 2007
    Richmond, VA
    162 - Get your engine temp into the operating range, allowing thermostat to open and water to circulate through cooling system - including the heater core. Then run antifreeze through the cooling system. Disconnect heater supply and return lines at the engine block. - Deerfield
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
