Results 1 to 10 of 10
04-14-2010, 05:24 PM #1
Tower moves a ton while trailering.....
Just got back from my yearly trek to AZ to go ride and I noticed that this time that my tower moves quite a bit while pulling. This is probably cause of all the horrible back roads we took to get there faster.
My main concern is it causing small spider cracks in the gel coat that end up looking like crap.
Any ideas......you guys have the same problems at all?
04-14-2010, 05:43 PM #2Sold my Moomba. Currently boat whoring.
Set Ups - 09 CWB Transcend Platinum w/ 09 Ronix Cells (his) and 08 Liquid Force Angel w/ 08 Alloys (hers)
04-14-2010, 05:56 PM #3
got heavy speakers up there? maybe remove them
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
04-14-2010, 06:56 PM #4
What boat do you have? Stock tower? What's on the tower when towing?
I ask as we don't exactly have some of the best roads in Cali either and i hardly notice mine move at all.2007 Mobius LSV
04-14-2010, 06:59 PM #5
I have an 07 Outback, stock tower. I have a bimini and a set of tower speakers (four total). Never have noticed a problem going to local lake only on long hauls and we take several of them a year to AZ and Powell.
04-14-2010, 07:06 PM #6
All towers move, some worse than others. I've seen some that will move side to side 8-10 inches. It's normal when you have a mass that sticks up like for inertia to take hold. For anyone to make one that doesn't flex at all would be either too heavy for the boat or extremely ugly! The four speakers aren't helping any though being way above the center of gravity as they are. You might look into some type of quick release mount for them. As said check all the mounting bolts and backing plates as well.
04-14-2010, 07:17 PM #7
Checked the bolts they are tight.....just searching for any type of quick release mounts....or just deal with it might have looked worse than I thought after driving a thousand miles!
Old Boat: 07 Moomba Outback
New Boat: Malibu vRide........and surf boards!!!
04-14-2010, 08:28 PM #8Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
04-14-2010, 10:25 PM #9
When i had my KMT's up on the tower last summer i didn't really notice to much tower wobble while driving. Now when in the water with the board up in the racks, ohh man that tower would move and wobble a lot. I had it looked at by AWS because i was pretty worried. They said its engineered to wobble and as long as the bolts are tight there's not much you can do.
Just keep the tower as light as possible.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
04-14-2010, 10:34 PM #10
2009 - You need to get under the deck and check the backing plates. Two things: 1) make sure the factory correctly placed the plates so the bolts actually go through them and 2) make sure that the nuts are tight. I have the exact setup ('07 Outback w/ factory tower) as you, without the speakers. - Deerfield
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
