Results 1 to 5 of 5
04-12-2010, 07:46 AM #1
WetSounds 420 Upgrade and install
I wanted something better to control my tower speakers from my boat speakers. The WS 420
so I did this install today
some parts, also two 8x8 galv angle brackets not shown
monstercables 15ft picked up for $5 stretching out09 21v LAUNCH
99 Outback LS. Sold
04-12-2010, 07:48 AM #2
cables run from amps to driverside
thru middle locker
to controller after 8x8 angle installed and fibreglass panel drilled and mounted09 21v LAUNCH
99 Outback LS. Sold
04-12-2010, 12:54 PM #3
wires placed in loom and final helm pic fished wires under amp board and thru back holes... didn't have enough time to post these pics
99 Outback LS. Sold
04-12-2010, 10:02 PM #4
its a galvanized 8x8 angle building tie from Rona, but Home Depot or any lumber place should have them
2-8x8 galv angle $6 each 12
4-16.4 ft monster rca cables $5 each 20
misc nylocs ,stainless screw ,ties,connectors,loom 30
total w kingdom tax ~70
labour priceless
4 holes drilled into dash(holes in 8x8 lined up nicely), 4 holes drilled into 8x8 to mount ws420, run wires from ws to amps and one to head unit output (used multimeter to determine which one), fish wires behind amp board, run power control wire to pcont wire off of head unit , remove female red and black power wires off switch , add male to red and black ws 420 wires with new feed wire, connect to female red and black, add new female on other end of new wire and attach to stereo switch, connect power control wires, clean up with 1/2" loom and cable ties. Also run wire for remote turn on coming out head unit, thought this might get rid of small speaker turn off pop when using the main stereo power button. There is no pop when the head unit power is turned off.
Tune stereo as per instructions with ws 420 and enjoy a beer in your boat with new tunes
Special thanks to jonybLast edited by DOCDRS; 05-17-2010 at 10:21 PM.
99 Outback LS. Sold
04-13-2010, 09:01 PM #5Junior Member
- Jul 2009
- Fishers, IN
- 21
Thanks for all the great pictures docdrs. I am getting ready to add Wet Sound tower speakers and the 420 to my boat. You really helped me out.
