Results 1 to 6 of 6
Thread: middle ballast empty pump ?
04-12-2010, 10:09 AM #1Senior Member
- Aug 2005
- 134
Anyone know where to buy this pump. Red and white pump held in a bracket. One more thing do your ballast fill up a bit just cruising around.?
04-12-2010, 11:50 AM #2
Which bag are you referring to, one of the ones in the rear or the ski locker bag?
15 Mondo Surf Edition
02 LSV - Traded In
04-12-2010, 11:57 AM #3
If you want a cheap fix go to Walmart, they have them for $15. I believe they have anywhere from 300gph to 900gph. They are basically the same pumps that are on our boats.
04-12-2010, 01:59 PM #4Senior Member
- Aug 2005
- 134
Ski locker, Jesse ,finally got that backroll..thanks
04-12-2010, 02:05 PM #5
Excellent. I have not been on the water yet this year. Does your ski locker pump just sit on the bottom of the locker or is it mounted else where. Mine is threaded directly on the bag and just lays on the floor. Pretty much anything with threads can replace mine. How is yours setup?
02 LSV - Traded In
04-13-2010, 07:49 AM #6Senior Member
- Aug 2005
- 134
Mounted in locker. I took the threaded part off and stuffed a wine cork in hose . Now I can size it with new pump. Thanks.
